Old 30th January 2004, 11:53 PM   #1
maylar is offline maylar  United States
Default WinISD response curves
It seems that just about every 10" subwoofer I try in a sealed box, WinISD says the -3dB point is about 50 Hz. Like a JL 10W0-8 it says 46 Hz. Whatzzup wid dat?
dave
Old 31st January 2004, 01:13 AM   #2
Immo_G is offline Immo_G  Australia
A 10 inch sub in a sealed box would be about that, I guess try a larger box if you want to lower it.
If you really want full bass extension, go a medium sized ported box, or a 12 inch sub, or both.
Old 31st January 2004, 10:10 AM   #3
Circlotron's Avatar
If the Qts is too low it will not work well in a sealed box but roll off too early. In WinISD open the parameters box and double click on the Qts figure and change it and see the effect it has. This will give you an idea of what to look for. Recently I came to the conclusion that 0.5 is best for a bass reflex box, and 0.7 is best for a 2 chamber 2 port bandpass. IMHO of course. You can raise the Qts by putting a small amount of resistance in series.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 31st January 2004, 03:17 PM   #4
But these subs are specifically intended for sealed box applications, and WinISD comes up with the same size box as is recommended by the speaker manufacturer. I've used the JL in my car and it went pretty darn low. Certainly below 50 Hz.
Qts is about .40
What's the point of a big subwoofer if it's not gonna go any lower than a 6.5?
dave
Old 31st January 2004, 10:59 PM   #5
dooper is offline dooper  Canada
Qts is about .40
I'd suggest that a car is a pretty small room, and provides a fair bit of bass lift. That driver in that box might not go any lower that some 6.5's, but with the increased cone area, Xmax and power handling, it should be able to move a heckuva lot more air.
JMO,
dooper
Old 1st February 2004, 07:46 AM   #6
owdi is offline owdi  United States
owdi's Avatar
A car provides a TON of gain below about 50hz, so that a sub with an F3 of 50hz is usually ideal for getting flat response without eq'ing. The bigger the car, the lower the frequency at which you get the gain.
Dan
Understanding Zaph's Frequency Response and Power Handling Curves jarsoffart Multi-Way 5 24th March 2009 08:29 PM
Optimum frequency response curves in the bass range The golden mean Subwoofers 8 30th June 2008 05:22 PM
Which would you go for? (with response curves) pdq2 Subwoofers 7 15th March 2008 02:51 PM
Derive Triode Curves from Pentode Curves? dsavitsk Tubes / Valves 3 14th May 2007 06:10 PM
SEAS standard line, and ugly frequency response curves Bricolo Multi-Way 14 14th December 2003 12:05 PM
Page generated in 0.15862 seconds (46.23% PHP - 53.77% MySQL) with 10 queries
