Old 30th January 2004, 08:01 PM   #1
Default Does this Baffle Sound Bad???
Tatoturbo posted the following pic in the Permanent Thread for Systems & Descriptions. I like the shape of it and wondered if that kind of flare around the speaker was a good or bad thing for sound.
Probably a silly question, but ........
Old 30th January 2004, 08:22 PM   #2
Bill Fitzpatrick's Avatar
If this isn't a sub I would have issues with how far the driver sits back from the rim of the flare.
Old 30th January 2004, 08:31 PM   #3
Hi Bill,
I looked at the pic again & it seems like the speaker sits a little back from being flush at the lip of the flare. If it was made to be flush with the lip that would be better right?
Also would this kind of flare be a bad thing for diffraction (woofers and tweeters)?
What's the difference if it's a sub or not?
Ralph
Old 30th January 2004, 08:43 PM   #4
Subs would tend to have thicker rims necessitating a deeper rabbet.
Looking at the picture of his woofer, it seems it will be recessed. Not sure how he did it. Did he use that ring as a spacer and the woofer rests inside it? It wouldn't be difficult to make the woofer reasonably flush with this design. Maybe he's flushmoutning a grill.
However, I wonder what having that hollow chamber between the fiberglass and wood would do. It would be great if you could fill it with sand which would be doable if you glued the rear panel on last.
Old 30th January 2004, 09:16 PM   #5
SY's Avatar
Well, there's also the wavelengths to be considered. At bass frequencies, that little bitty edge isn't going to diffract much.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Will routing edges of front baffle affect sound? Ken C Multi-Way 12 3rd December 2004 08:57 AM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
If a baffle is 2 meters wide, what is the frequency where the sound 454Casull Multi-Way 18 2nd August 2004 08:18 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 03:43 AM
Page generated in 0.07376 seconds (71.82% PHP - 28.18% MySQL) with 11 queries
