Help with the unknown - diyAudio
Old 22nd March 2015, 12:34 AM   #1
Moovnutz's Avatar
Default Help with the unknown
Greetings y'all,
Dr.Troels says on his Jenzen-Next page Jenzen-NEXT
One could swap this driver W26FX-002 with this CA26RFX.
Working with the Jenzen Accu mkII, could you swap the Audio Technology 10C77-25-10-KAP bass driver for the CA26RFX?
No small animals will be harmed Your friend, M
"Everything rolls one way when you're walking up hill"
Old 24th March 2015, 02:45 AM   #2
Moovnutz's Avatar
Did I mention free cheez whiz was involved?
The silence is golden!
ah..Houston I'd say we have a go.
Light em up boys!
There goes my DIY career
Thanks for the help
Old 24th March 2015, 03:18 AM   #3
Inductor's Avatar
In the middle of the page for the 10C77 you have a comparison ""Left: AudioTechnology 10C77-25-10-KAP. Middle: ScanSpeak 26W/8861T00. Right: SEAS W26FX002.""
But, a TL is a complete different animal. Model a TL for both drivers and check it's swapping possibility. Are you doing it in a TL? H1305-08 CA26RFX - Seas
Jenzen-NEXT
Jenzen-Accu
10C77
Estoril Jazz/2015
Old 24th March 2015, 03:44 AM   #4
Moovnutz's Avatar
ER hold the lidocaine, we have a bump in the line. Breath!
Wow thank you for your response
I plan......if all goes well to do a 4-way with the bass and sub, dsp driven.
I would like to know if my request was valid so I could use bass circuit for a/b comparison.
the W26FX002 or the CA26RFX are my druthers due to budget.
I want to experiment running 'em up to 3-600hz and cutting them off at 80hz.
Closed for the TL as in same baffle, same carcass but closed, maybe a resonator at the bottom like the Scanspeak Factum.
Your friend M
Old 31st March 2015, 06:16 PM   #5
Inductor's Avatar
Can you make a question at (each) one time (makes things easier for me) with links if possible.
There are 3 type more common of speakers, sealed, BR or reflex and TL transmission line, ok. I understand that by resonator you mean the bass reflex, so it can not be closed (or sealed).
Would be nice if you address your question again with the right vocabulary in mind, if possible. NPI
Estoril Jazz/2015
Old 31st March 2015, 09:50 PM   #6
Moovnutz's Avatar
Sorry Le, I didn't notice your flag (Portugal).
This speaker: Jenzen-Accu
I understand the difference between Sealed, ported,TL..
Look here Defaktum: Scanspeak Three-way
Second picture down. The German designer used a Helmholtz resonator at the bottom of the box. Is there a formula to calculate this in the Jenzen speaker?
Old 31st March 2015, 10:01 PM   #7
Moovnutz's Avatar
Inductor,
I hope I was clear. You can make a whole wall in your house with holes and stuffing or other material. These holes are not random but calculated depending on what mode you want suppressed.
obrigado
M
Old 1st April 2015, 01:40 AM   #8
Inductor's Avatar
Oh ok!
I knew you were picking something more dangerous from your pocket...
Originally Posted by Moovnutz View Post
...Helmholtz resonator at the bottom of the box. Is there a formula to calculate this in the Jenzen speaker?
In French, sorry*.
"Le bass-reflex à résonateur"
*I can assist you in what I know.
Estoril Jazz/2015
Old 1st April 2015, 01:56 AM   #9
Inductor's Avatar
Try also googling the terms you need. As for diy bass traps or similar.
Is that for a speaker or for room modes? You mention in wall that's why me asking.
Some links you may relate to:
Q. What kind of bass trap do I need?
Bass Traps 101 - Your Guide to Corner Bass Trap Placement
Steven P. Helm: DIY Bass Traps
Build a Better Bass Trap
Estoril Jazz/2015
Old 1st April 2015, 02:13 AM   #10
Inductor's Avatar
I read from link on post#8 they are the same calculations used by ELIPSON.
I will have to read the Jenzen Accu mkII/Faktum loudspeaker for more info.
Estoril Jazz/2015
unknown book angelp4492 Parts 1 13th February 2013 05:46 AM
Another unknown tube rotaspec Tubes / Valves 3 3rd September 2012 10:22 AM
capability unknown- sekhar Solid State 30 16th March 2010 03:40 PM
unknown SUBWOOFER nuteronix Subwoofers 1 18th June 2006 03:05 PM
Unknown part(s) ifrythings Parts 5 29th May 2006 07:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
