Old 31st January 2004, 09:56 AM   #21
Maybe this 8" Flexunit is a nice compromis. however only 91 db/w/m
You can request for adjusted T/S parameters
http://www.flexunits.com/iz.asp?id=4|a|125|||
Is that all there is?
Old 31st January 2004, 03:00 PM   #22
diyAudio Moderator Emeritus
roddyama's Avatar
Vortex,
You might think about a power subwoofer to take care of the bass below 80Hz or so. This will give you a bit wider selection to choose from. Although, high sensitivity and wide bandwidth will still nerrow your search to a only a hand full of speakers. It's more than you have now.
Rodd Yamashita
Old 31st January 2004, 03:37 PM   #23
Vortex is offline Vortex  Hungary
Vortex's Avatar
Send a message via ICQ to Vortex Send a message via MSN to Vortex
Vigier:
BTW: 120 and 8 kHz? Why? I would suggest 200/300 Hz and 3500/4000 Hz.
Then you have all the voices through the mid-unit, and it doesn't have to be SO small to prevent standing waves/cone breakup and other annoying stuff
I don't really understand the end of it...
Let's discuss it in 3 pieces:
1) eg. 250Hz versus 120 for lower x-over freq. why better? 12db/oct. still goes higher pretty much. It means then still more mid range for the low freq. driver which I then try to choose by going for ultra high-quality sound.
2) range of the normal audible speak is the job of the high-subs and midrange of course. that's why I tried to avoid 3-way, because this is the most crital area of our ears, where because of a 3-way filter a phase shift occurs. (still confused, 2-way just sounds amazing for me)
3) 3.5K-4K is okay (versus 8)
But anyway, it will be 3-way I think. Something like the Visaton Athlas Mk-II (beautiful piece).
Let me bomb with another ideas regarding construction. Just critisize me pls... I'd like to do my best which fits my tube amp.
Probably I can get out 10W per channel from the 2A3 tubes. It's like some kind of a 50-70 watt conventional amp. I've heard one of my friend's Audio Innovations First 7W tube amp with Audio Note boxes (silk dome tweeter and 8"/20cm paper midbass) and IT WAS REALLY LOUD at a half-turned-on volume !!! Amazingly loud can these tubes perform...
but let's go back to the point... still like my old C64 ..
LOAD"high-end DIY box",8,1
SEARCHING FOR...
Old 31st January 2004, 04:30 PM   #24
Vigier is offline Vigier  Netherlands
Hi Vortex,
the reason I prefer 250/300 Hz above 100/120 Hz, is because of the excursion/distortion.
If the midrange has to go as high as 4 kHz, it will be a very small unit. It won't be able to go down to 100 Hz. The excursion will be too high.
For example the TI100 (as midrange) has a lin. excursion of 3mm (and I can tell you the mech xmax isn't very much higher).
It will go over it's lin xmax at 100 Hz with just under 2 Watt!
If you use 250 /300 Hz, you can use the full 7W. (excursion is much lower)
Grtz, Joris
Old 31st January 2004, 07:18 PM   #25
Vortex's Avatar
Aham. Right.
One another question: I like the construction of the Visaton Topas. Transmission line for the TI-100 as I see. They also made the construction of the box with exact data public.
Would this box perform quite well if I would a bit make it bigger?
To hold all of the angles and not to loose the size to size ratio, I would multiply every data given in centimeters so that finally the same box but something bigger would come out. Would it be a good idea, or shall I forget it ?
I also enlarged my father's Carlson-type box 4 years ago which was designed for 8" drivers. I resized and made it again to be able to build a 12" speaker in. It worked well, VERY WELL !
Old 31st January 2004, 09:03 PM   #26
Hi Vortex,
I have the issue of Klang&Ton where the article about the Topas is in.
I have no experience or knowledge about horns, so I can't helkp you with this.
Grtz, Joris
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
7" midbass and 1" tweeter for 60$ and 30$, what about SEAS? Bricolo Multi-Way 23 20th July 2007 04:35 PM
high efficiency 10-12" midbass drivers Puggie Multi-Way 3 19th August 2005 03:35 PM
choosing 8" or 6.5" midbass neon Multi-Way 11 19th March 2005 04:32 PM
best midbass for a horn "mini" monitor? E. Billeci Multi-Way 2 13th January 2004 06:46 PM
Page generated in 0.08776 seconds (77.01% PHP - 22.99% MySQL) with 10 queries
