Three speakers to two channel amp? - diyAudio
Old 5th March 2015, 09:48 AM   #1
ODougbo is offline ODougbo  United States
Default Three speakers to two channel amp?
Been looking on the web for an answer to this question and not finding much.
How to hook up three speakers to two channels?
Filling the room with sound on a tight budget is the goal, willing to sacrifice stereo separation.
The sketch may be the most common way, but unsure.
Another solution may be wire two speaker parallel (4 ohm) and add a heavy L-pad to the remaining 8ohm speaker for balance.
Any recommendations?
Old 5th March 2015, 10:01 AM   #2
S4m is offline S4m  Germany
S4m's Avatar
Hi ODougbo,
Is the drawn amp the amplifier the one you are using for this setup?
AFAIK the Topping/class-D/class-T amps have a huge problem with changing impedances.
Using the (+) of the left and the right channel is often used in car-hifi and seems to work very well.
If you have a nice simple solidstate-amp I would advice you to try it in first instance with this one.
Edit: Add an L-Pad to the speaker to adjust the level. It can be louder than the left and right channel speaker.
Old 5th March 2015, 11:01 AM   #3
Thank you S4m,
Concerned that the digital might not be the best choice.
We do have low cost alternative: Audio Source Amp 100
Old 5th March 2015, 11:17 AM   #4
Switching the three speakers in series and bridging the power amp could solve the equation. But of course you need an inverter and a few resistors to bring the stereo signal back to mono. Alternatively switch two speakers in series and hook them up to either L or R and connect the remaining speaker to the other channel. That wouldn't cause any problems to the amp.
Old 5th March 2015, 08:59 PM   #5
sippy is offline sippy  United Kingdom
This post might be of help: Master Nagaoka Tetsuo explorations on matrixed single stereo speakers
Old 5th March 2015, 10:08 PM   #6
Note that most matrix circuits assuming a common
earth won't work well with the Topping at all, as it
bridged and there is no common earth.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 5th March 2015, 10:35 PM   #7
Sippy- thanks, for the link, very interesting. Will try the wiring on 1st post.
Sreten, thanks, going to try the low cost bridgeable amp.
Have a few options now!
These can can be found on sale for $99
http://www.amazon.com/AudioSource-AM...+source+Amp100
Old 5th March 2015, 10:39 PM   #8
What part of it won't work well do you not understand ?
rgds, sreten.
Old 6th March 2015, 01:54 AM   #9
AllenB is offline AllenB  Australia
What do you mean won't work well?
Is this (per channel) a pair of parallel amplifiers with balanced feed (through a phase splitter from unbalanced inputs) and the outputs taken balanced as well? As if this is the case they are all still referenced to ground, as are both of the input channels.
Old 6th March 2015, 02:01 AM   #10
rgds, sreten.
Didnt know that!
First leaning of the day for me on diya
Small Speakers for 5 channel single ended amp ryuji Tubes / Valves 54 13th April 2011 12:49 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers mark.carline Multi-Way 5 18th May 2004 06:03 PM
4 speakers, 2 channel amp, 1 crazy idea muskgrave Car Audio 31 6th April 2004 12:13 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
