How much volume do I get for 3w RMS? - diyAudio
Old 26th February 2015, 05:57 PM   #1
gasboss775's Avatar
Question How much volume do I get for 3w RMS?
My speaker is rated at 88db @ 1 watt, what volume would I get at 3 watts?
Old 26th February 2015, 06:10 PM   #2
Rule of thumb double your power you get 3 db louder so 2 w would be 91db so
3 w would be ~ 92 db. Depending on your choice of music etc. this can still be
enjoyable.
Old 26th February 2015, 06:15 PM   #3
rayma is offline rayma  United States
Originally Posted by woody View Post
Rule of thumb double your power you get 3 db louder so 2 w would be 91db so 3 w would be ~ 92 db.
Depending on your choice of music etc. this can still be enjoyable.
This would be on peaks. Average power would be 6-20 dB lower, depending on how much the music is compressed.
Uncompressed acoustical music would especially need the most headroom.
Old 26th February 2015, 06:16 PM   #4
IG81 is offline IG81  Canada
IG81's Avatar
10*log(3W) =: 4.77121dB louder than reference sensitivity.
Old 26th February 2015, 09:16 PM   #5
gasboss775's Avatar
Thanks all for your responses.
Average volume definitely higher with modern pop song ( lots of compression I'd guess )
It turns out I wasn't even putting out 3w from my experimental class a amplifier more like 2 w though should be able to squeeze out another 1/2 watt by optimizing the bias.
Old 27th February 2015, 10:33 AM   #6
If you play music with an average dynamic range (say 12dB) you are merely adjusting distortion if you listen above 80dBspl average.
With modern pop (6dB DR) that point is reached at 86dBspl (92dB - 6dB range).
With a really good classical recording (20dB DR) the average listening level should not exceed 72dBspl.
Of course this is all at 1m distance. If you are further away from the speakers reduce average levels accordingly.
Old 2nd March 2015, 08:29 AM   #7
I am not sure I understand the dynamic range argument. If the DR is 20dB, is that from the loudest to the quietest. If so isn't the average, half way; 10 dB down, in this case 82 dB? Which is fine for a lot of listening.
Old 2nd March 2015, 09:45 AM   #8
norman bates's Avatar
eh, I like speaker + amp at 100db, unless I want to crank it a little.
So 3w + 88db would not be enough for me.
If I had your speakers, I'd need +12db.
50w = +17db
25w = +14db
So, I'd say you need a good 20 watts.
Probably 10 watts of a tube amp assuming load is fairly flat.
Old 2nd March 2015, 11:02 AM   #9
log 3 then multiply by 10.
i.e. 3W = 4.77dBW
now add that to the speaker sensitivity.
88dB/W @ 1m becomes ~92.8dB @ 1m
If you listen @ 2m then subtract ~ 6dB giving ~82dB @ 2m as your maximum volume.
regards Andrew T.
Old 2nd March 2015, 11:09 AM   #10
speaker dave's Avatar
This is more a measure of crest factor. That is, the difference between the long term average and the short term peaks. What others are saying is that if you set your volume such that the peaks are just below clipping, then the average volume will be lower by an amount equal to the crest factor.
High crest factor (or high dynamic range) requires higher peak power if we want a given average loudness level. It is still a good thing.
David
Increasing power of PAM8403 3W+3W amplifier board Wilfrid Class D 5 1st February 2015 02:57 PM
class AB 10.000W RMS @0.5R - 20.000W rms bridged dovizci Solid State 46 4th September 2014 12:06 PM
520w rms 4ohms to 8ohms rms conversion jonpaulmusic Class D 3 11th July 2013 01:50 PM
Workaround to measure RMS on a non-rms meter percy Equipment & Tools 9 13th March 2006 04:48 PM
Clipping? why not build amp with twice rms needed and only use half volume? John Biles Everything Else 22 29th September 2005 06:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
