Old 28th January 2004, 03:58 PM   #1
Sheldon is offline Sheldon  United States
Default "That's not a woofer, THIS is a woofer"
http://www.royaldevice.com/custom3.htm
Got this from the DIY speakers list. May have shown up here before, but it speaks to commitment (or the need to be committed).
Sheldon
Old 28th January 2004, 04:48 PM   #2
This shows up yearly on the forums..
It's kinda small isn't it
Old 28th January 2004, 04:52 PM   #3
Tensop is offline Tensop  Lebanon
The sad thing is that something bigger has probably been jammed into a car for an SPL Competition somehow
Old 28th January 2004, 04:57 PM   #4
tiroth is offline tiroth  United States
What really scares me is how dreadful the room looked after all that effort and money. You would think that aesthetics would at least be considered...especially after laying out so many $$$ for the marble.
Old 28th January 2004, 05:05 PM   #5
Send a message via ICQ to tpenguin Send a message via AIM to tpenguin Send a message via Yahoo to tpenguin
Those cwazy tube people . It's quite an impressive accomplishment, if a little on the extreme side. I wouldn't mind a refrigerator-sized sub enclosure, but I'm affraid I'd have to draw the line at building an addition onto my house to put woofers in. But then again, whatever floats your boat...
Old 28th January 2004, 05:30 PM   #6
diyAudio Moderator Emeritus
roddyama's Avatar
Originally posted by tpenguin
..., but I'm affraid I'd have to draw the line at building an addition onto my house to put woofers in.
An addition is not required. You only need to convince your wife to do the laundry in the sub's compression chamber. Wash in the left and dry in the right.
Rodd Yamashita
Old 28th January 2004, 06:02 PM   #7
RHosch is offline RHosch  United States
I've perused that site numerous times, and something about it just strikes a raw nerve. And it isn't even their obsession with NO FEEDBACK designs. It's the 20 speakers used for the L/R channels (not including subwoofers, apparently). They look like some form of back horn loading or transmission line. With the description of "no crossovers" used at the top of the page, I can only assume that the drivers you can see (around 10" or so it appears) are running full range.
Great... if you have one of them. I mean, really... the whole purpose of running a full range driver is to avoid phase distortion through a crossover region, but equally important, IMO, is that you avoid having multiple spaced drivers with the associated comb filtering. If you really need more SPL, use two, but by all means keep them as close as possible.
Take a look at the spacing of drivers in that wall of front speakers. The in-room lobing error must be phenomenal (phenomenally bad). I don't care how low the distortion from each speaker is (not very after cone breakup sets in), or how flat (not very, if those suckers are running full range) each speaker is... the resulting frequency response vs. position must look like a plot of a bed of nails. Geez... And that represents the "most esoteric" listening room in the world? They can keep it.
Nice subs though.
Old 28th January 2004, 06:56 PM   #8
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Default Agitator
So, if you continue to increase the amplitude, can cavitation be achieved as in an ultrasonic cleaner? Would this then be a subsonic cleaner? If cavitation cant be had, a LF sweep and traveling waves would certainly get the suds going.
Perhaps the sub becomes the washing machine.
(capitation? spell check is dangerous to the inept)
Old 28th January 2004, 06:58 PM   #9
While I think the walls of speakers (and trying to run 10" drivers all the way from the bottom of their frequency range to the top octave) are really dumb ideas. The "abosolutely no feedback" philosophy is abosolutely stupid. In addition to the fact that the amps will generate an obscene ammount of distortion regardless of how low the distortion generated by the speakers is, having absolutely no DC offset correction means that a single screw-up with a connection or even a nearby lightning strike could cause all 24 (at least what I counted) of their drivers to go flying out of their baskets. Efficiency is good, but just trying to make as much noise as possible out of a tiny tube amp is just not the way to go. As for their listening room being esoteric, that is only because most audio people would not be caught dead with all that crap (maybe with the exception of the sub) in their listening rooms.
If they think getting 100dB from 1W is so great, why don't they just listen to smoke detector piezo buzzers?
Old 28th January 2004, 08:02 PM   #10
JOE DIRT®'s Avatar
does that come in a kit?
von schweikert unifield 3, an offshoot from "fullranger with helper woofer" d to the g Multi-Way 15 24th September 2008 10:34 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 3 2nd January 2006 02:04 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
Page generated in 0.10261 seconds (81.46% PHP - 18.54% MySQL) with 10 queries
