TQWT Gradient W 160 AL
Gradient
Yes it is here are the spec's
Nennimpedanz/Gleichstromwiderstand: 8 / 5,94 Ohm
Resonanzfrequenz: 43 Hz
Gütefaktoren(Qms/Qes/Qts): 2,3 / 0,62 / 0,5
Äquivalenzvolumen(Vas): 20 Liter
Effektive Membranfläche(Sd): 125 cm²
Schwingspulenüberhang(Xmax): 3 mm
Schwingspuleninduktivität(Le):0,47 mH
Hi everyone,
seems I was the one GM helped doing some simulations for the W160 AL. I have built a 42" MLTQWT following his plan and am very satisfied.
The Gradient W160 AL is a quite affordable aluminium woofer with lots of resonances in the upper frequency range.
http://www.spectrumaudio.de/breit/gradientW160AL8.html
German magazine Klang+Ton recommended to just ignore the resonances and use the woofer as a fullrange driver. Those people were right. The Gradient W160 AL represents a philosophy opposite to most Fostex fullrange drivers: Bass down to 30 Hz is no issue and enough Xmax - but highs should be more refined.
