Old 27th January 2004, 05:35 AM   #1
Speakerholic
Cal Weldon's Avatar
Default Two woofers vs. one
I have this old JBL 8" with passive radiator full range system. The LE8T's failed and I replaced them with some knock off woofs, 4 ohms. Added a super tweeter and voila an instant, sturdy box, two way system.
A couple of years later the PR's went and I got two more woofers. Wired them in series because I had too, and found the drop out in bass to be disappointing.
Two questions:
1] Was the drop in bass due the series now being 8 ohms and that the power was not being delivered to the drivers and or:
2] Was the cabinet was designed for the one driver with PR and the second is competing for "air space"? That's a decent size cabinet for an 8" driver.
Thanks for your responses.
Go easy on me with the explanation.
Cal
Old 27th January 2004, 08:05 AM   #2
just another
wintermute's Avatar
My guess would be that you've changed the box from "effectively" a vented to sealed enclosure. I say effectively a vented box, because Passive radiator boxes behave very much like vented boxes, with the accompanying bass extention. By changing it to sealed, and adding a second driver, you've completely changed the alignment probably non-optimally, and hence the loss of bass.
Even if the volume was optimal for the two woofers, you still probably wouldn't get the same bass extention as with the PR.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th January 2004, 10:54 AM   #3
Coolin is offline Coolin  Netherlands
Coolin's Avatar
I understand That "PR" are only used so you are able to reach low with a smaller box volume than when ported normally.
So by using the dual woofers the box volume is something like 3 times too small to reach the same low.
The PR also has the advantage of being tuned lower than the woofers.
CO
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
Using three woofers rackmount Subwoofers 1 8th November 2006 01:16 PM
PHL woofers!!!! tadman Multi-Way 21 9th June 2004 10:58 AM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Using DVC woofers as 2 seperate woofers Hybrid fourdoor Multi-Way 2 15th June 2003 12:10 AM
Page generated in 0.07485 seconds (70.04% PHP - 29.96% MySQL) with 10 queries
