Old 27th January 2004, 02:58 AM   #1
Send a message via AIM to Chris8sirhC
Default novice open baffle line array question
Recently i bought 42 of the parts express 4'' full range drivers they have on sale for .80 cents or something like that.
Since that driver has a nasty spike at 7khz, would doing something like this at least partially cancel out that peak?
http://f2.pg.photos.yahoo.com/ph/chr...&.dnm=3c54.jpg
where a=4.9 cm (equivalent to 7khz) and x is some undetermined length.
maby im completely off base here, its just a thought.
Old 27th January 2004, 02:19 PM   #2
leadbelly's Avatar
The peak is 9 dB....that's HUGE. Playing around with the baffle won't even get you close. You need to look at things like coating the driver with Damar or Puzzlecoat, adding a passive notch filter, etc.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th March 2004, 07:05 AM   #3
Default Building same
Hello. I am so glad to see that I wasn't the only one lured in by those 4 inch Pioneer drivers.
This is my first speaker construction in 25 years. I am designing an open baffle line of 16 speakers each side. Add a pair of Fountek JP3 ribbons for the highs and an old Janis subwoofer for the bottom end.
The Pioneers are damped by sticking 2 sided tape inside the metal frames. The cones are lightly doped with Dammar. This smoothes the upper midrange and treble. Luckily, the 7k spike seems to disappear a little off axis so I am positioning the speaker faces parallel to the rear wall. More difficult to fix is the 6 db wavelength-equals-cone-circumference trough at 1400 hz. Does anyone have more clever idea than notch filing?
Unless you build a curved array, you will likely find combing above 3400 hz objectionable. It's not just the drooping highs, I find it de-focuses the imaging unless you filter out the top end of the array.
I hope this helpful. If you haven't already discovered James Griffin's Practical Guide to Line Arrays, I recommend reading it.
Thanks, captpeterchan
Old 14th March 2004, 08:24 AM   #4
Svante is offline Svante  Sweden
Svante's Avatar
You might want to experiment with the (open) baffle placement using the Edge. Remember large arrays are sensitive to listening distance. If there is a single peak at 7kHz I'd notch it with a passive parallel LCR-circuit.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 14th March 2004, 11:47 PM   #5
Default Re: novice open baffle line array question
Originally posted by Chris8sirhC
[Bwhere a=4.9 cm (equivalent to 7khz) and x is some undetermined length.
maby im completely off base here, its just a thought. [/B]
Using a = 5cm will give you a very high (siily high) baffle roll-off.
sreten.
Old 15th March 2004, 11:55 AM   #6
Svante's Avatar
Default Re: Re: novice open baffle line array question
sreten.
Really? When I try to simulate this, the distance to the edge does *not* seem to be terribly important to the roll-off frequency. Then again I wrote the simulation software myself, but I think it is OK. It appears to me that the baffle width is the most important.
...or am I missing something here?
The green curve has the driver array centered on the baffle, the red has it 5 cm from the edge.
Old 16th March 2004, 02:35 AM   #7
I built a couple of open baffle line arrays last month. http://www.diyaudio.com/forums/showt...688#post337688 In fact, I'm on to building another set as we speak. The second set will use a couple of Dayton ribbon tweeters per cabinet. I will confess to being a new array fan (until I build my first horn).
I guess the reason I jumped in on this thread is to say that you should just go ahead and build 'em. From a risk/reward standpoint, you are wagering a sheet of 3/4" mdf. Low side is 30 bucks, high side (veneer) is a C-note. Let's face it, the drivers were below scrapyard prices when we bought them. Maybe you even have some caps 'n coils to play with the x-over. On my first set I capped the tweeters and haven't looked back yet. On the second set, I will invest in some coils and tune them up a little.
I am no audiophile, but I like to listen to music, and sometimes I like to listen to loud music. These things are like getting kicked in the chest. So, my own impression is that they sound great. I have had the opportunity to A-B-C them with the Klipsch and JBL's in the picture. The arrays clearly need some bass but they are my clear preference.
Step away from the PC and pick up a router.
Old 16th March 2004, 04:57 AM   #8
Default thank you svante for The Edge
I've already tossed in my two cents of ideas for this particular thread. I just wanted to thank svante for introducing The Edge. In a couple of hours, I had some baffle dimensions for the open baffle line array that I'm working on. Slim trapazoids --- of course??!!! Got some good graphs for the ribbon tweeter and for the 16 Pioneer woofers. Will build and listen before I start playing with compensation. Will be very happy to be no more than 6 db down at 100 hz. Couldn't find a way to just drop 7k hz. Again, thank you svante. This is why I joined up yesterday.
captpeterchan
Old 19th March 2004, 04:50 PM   #9
I actually built them 2 weeks or so ago, i was planning on putting them in a box, then i realized i didnt have enough mdf on hand, so i saw this sheet of 1/4'' hdf lying there... so in about 3 hours i had the left speaker finished. I used what mdf i had for a rear brace to keep the thing from faling over or bending. I must admit, for $30 they sure sound great.
Old 19th March 2004, 06:57 PM   #10
Svante's Avatar
Default Re: thank you svante for The Edge
Thx
Open baffle Line array carpenter Full Range 81 21st July 2010 10:50 PM
open baffle and/or line array lolojr1 Multi-Way 8 7th July 2006 04:47 AM
line array open baffle spkerguy Multi-Way 5 6th January 2004 08:42 AM
Page generated in 0.10853 seconds (82.85% PHP - 17.15% MySQL) with 10 queries
