Are these caps OK for tweeter protection - diyAudio
Old 4th February 2015, 05:32 AM   #1
Default Are these caps OK for tweeter protection
I'm building a 2-way bass-reflex speaker with a Vifa XT25TG tweeter. It is bi-amped and has a 24dB/octave LR crossover at 1400Hz.
My research tells me that a 35uF cap should be OK for protecting the tweeter from DC.
I couldn't find a 35uF cap in my travels, but I did find these for $3 each. Are MKP caps suitable for the job? Would 4 of these in parallel be OK? I guess I would just stick them to the cabinet with silicone?
The iPad charger gives you an idea of their size (they are chunky).
Old 4th February 2015, 05:38 AM   #2
Actually to keep the DC blocking cap from affecting the crossover region, for a 8 ohm tweeter you'll need about 140 uF, and double that for a 4 ohm tweeter.
Mike
Old 4th February 2015, 06:32 AM   #3
It's a 4 ohm tweeter, so 280uF huh? That's 28 of these caps! I reckon I'll get myself a motor-start cap in that case.
Old 4th February 2015, 06:49 AM   #4
No, motor start caps are not suitable for audio, use a motor RUN cap instead.
Mike
Old 4th February 2015, 06:55 AM   #5
OK, thanks.
Out of curiosity, how did you arrive at the 280uF figure?
Old 4th February 2015, 06:55 AM   #6
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
It makes no sense to use a hyper value cap for this purpose.
You might do yourself a favor and measure the raw tweeter
response with an appropriate cap to help realize what it does.
Old 4th February 2015, 06:58 AM   #7
Hi Lojzek,
So you are saying 280uF is bigger than I need? Can you suggest a suitable value please?
I intend to measure the response of the speaker when it's built.
Old 4th February 2015, 07:10 AM   #8
Lojzek's Avatar
You have said it yourself in the opening post.
Old 4th February 2015, 07:16 AM   #9
Tweet is offline Tweet  Australia
Chris,
Presumably you are using an active crossover and directly driving the tweeter from a power amplifier.
The problem with using such a high value of capacitance is that when the amplifier first switches on, if there is no 'de-thump' circuit in place .....this is usually a time-delayed relay circuit that connects the drivers after the amplifier stabilized, that high value of capacitance will charge itself through the voice coil of the tweeter as a large pulse of DC current.
That DC pulse will have a very low frequency component in it, it may well 'pop' your tweeter(s) if the charging current of the capacitor is high enough.
I would suggest to forget the capacitor and check if Jaycar or Altronics have a standalone 'de-thump' circuit you might incorporate to intervene between the amplifiers and your drivers.
C.M
Old 4th February 2015, 07:45 AM   #10
giralfino's Avatar
I just want to warn you that, according to someone who tested lots of drivers, and even used the same driver in its reference design (ZD5), the XT25 is not suited to a low crossover point. See the comments here: Zaph|Audio
Ralf
tweeter protection darren123 Multi-Way 7 6th February 2015 09:57 PM
Tweeter Protection? QikoCB7 Multi-Way 34 16th December 2013 06:13 AM
Combined DC protection and tweeter protection? CopperTop Solid State 10 13th January 2011 07:52 AM
Tweeter protection for active speakers paulspencer Multi-Way 31 26th October 2005 08:40 AM
Tweeter protection Cap static Multi-Way 13 14th January 2004 11:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
