Old 26th January 2004, 11:39 AM   #1
mikee12345's Avatar
Default Fixing woofer tear?
hello!
i have received this woofer-
How can i Repair its tear...
first thoughts-
Silicon
some sort of modeling cement
other glues..
i want to horn load it-but dont want distortion or stresses placed on the cone because of this
Cheers!
Old 26th January 2004, 12:48 PM   #2
Bull is offline Bull  United Kingdom
Default reply
You could try some epoxy resin glue on both sides of the tear.
But as it's for bass,i recommend you remove the dustcap and put a bit of glue the side next to the tear,because this is the next weak part around the tear,to rip.
Any woofer which has to move a great distance[subwoofer to 30hz] should be reconed because it's likely to tear again in a different place.
I've repaired many speakers like this[but failed to repair subwoofers though].
Will sound a bit different,but not distorted if you use epoxy resin glue to fix it,since superglues are light compounds and tend to 'buzz' when the cone moves,well thats what i've found.
An even better rubbery glue nicknamed 'elephant snot' which is black and lumpy but seems to be stronger than epoxy resin glue,and it's black so it doesn't show up on cones as much.
Old 26th January 2004, 01:03 PM   #3
pinkmouse's Avatar
To be honest, you really need a recone, but for a temporary repair, dab waterproof PVA wood glue on each side of the tear, then cut a little strip of tissue paper, and use a small paintbrush to push this well into the glue. Let it dry, then repeat on the other side of the cone. Let dry for 24 hours before using the driver. I have used this fix many times when I was on the road, both on guitar/bass and PA drivers, it works well and is relatively easy, but no repair like this is permanant.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th January 2004, 03:55 PM   #4
Speakerholic
Cal Weldon's Avatar
Clear nail polish. Often available in your wife's bathroom accessory bag. Don't use on poly cones.
Cal
Old 26th January 2004, 04:10 PM   #5
michael is offline michael  Australia
Send a message via MSN to michael
Maybe try fibre glassing it with a single thin layer one the back side of the driver, wont weigh much at all and will be very strong, even do 3 equal strips on the cone just t spread the extra weight so that the cone isnt out of balance. if you want super lightweight use carbon fibre instead of fibre glass and use thin epoxy as the glue as it is stronger and lighter than oply-whats its.
good luck
Old 26th January 2004, 05:20 PM   #6
markp is offline markp  United States
Use a strip of tracing paper and good old white glue on each side. Do it as thin as possible, about 1/4" on each side of the tear. It will weight next to nothing compared to the cone so balance wont be an issue. If it is too wide or thick it will cause the cone to fatigue at that point if it is more rigid that the surrounding area. Its not perfect but it will work.
If it sounds good... it is good!
Old 27th January 2004, 02:41 PM   #7
mikee12345's Avatar
Thanks for the tips everyone!
Im talkn to the guy who sent it to me,he said it didnt have the tear when it left his house-so were checkn the post office people now...
but because he didnt put 'fragile' on the box,they probably threw it around like a football ....
Old 27th January 2004, 02:44 PM   #8
mikee12345's Avatar
when i took that pic i forgot to put the camera on MACRO for <60cm shots...now its all butiful!
Old 30th January 2004, 06:38 AM   #9
I second Bull. Epoxy glue is the best.
I once did a repair using a very sepecial epoxy, PC-7. PC-11 is a slightly more expensive substitute. Very strong.
Spread as thinly as possible to cover the tear, both sides, let stand overnight. I do believe thay you can consider this a permanent repair, at least it seemed that way to me.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 30th January 2004, 06:39 AM   #10
mikee12345's Avatar
thanks KW!
hopefuly the post people will admit they threw it around too hard and wrecked it...and my mate will get a new one.
anyway,i wont be allowing people to send me woofers by mail like that.
It models well on the horn..also CERTAIN jaycars do aswell,the PROFILE 12" does...
Cheers!
fixing a crack in NS-10M monitor woofer gilwe Multi-Way 36 19th September 2008 01:29 PM
Tear in Driver Rubber Surround slhijb Full Range 4 27th July 2007 09:00 PM
Would this tear in the driver affect sound? (pic inside) wixy Multi-Way 1 6th January 2007 07:41 AM
Tear in magnetostat membrane: What to do? Klimon Planars & Exotics 2 1st March 2006 11:33 PM
Page generated in 0.11697 seconds (80.51% PHP - 19.49% MySQL) with 11 queries
