Please tell me there is a way to pull a cone back out that's been pushed in (my 2 year old son). I have a pair of Infinity towers with 6" woofers. The cone appears to be made of a dense foam, not paper.
#2 |
Did it Himself
You've probably got nothing to lose now... Try sucking them out by placing a vacuum cleaner in the middle/apex of the dome. I have done this on a few large dust caps.
#3 |
I use a flared port as a straw to suck out the dustcap.
#4 | |
No sweat, it's just a mod! If those two fail, consider poking a tiny hole in the center of it, then inserting a bent safety pin to pull it out. If that doesn't work either, cut the cone off with a knife, and make a plug. Dave |
#5 |
let's see, I have survived, at least until now, 3 male youths -- the first set of pushed in cones was in some KEF B110's -- I used the glass globe from a hurricane lamp to suck out the cone!
2 years old, huh, do they still make zwieback cracker? -- the only substance known to man which can't be removed from parental clothing! when he gets to college you can finally take the grills off your speakers. |
#6 |
The best for me and my 1 .5 year old who enjoyed punching my dust caps is a plastic suction cup like the ones used to attach to glass.If you wet it a tiny bit it has great pulling power.
#7 |
for dust caps, I have used 3 methods
1- vacuum cleaner 2- sucked (yep!) 3- carefully placed the corner of a square piece of gaffa tape on the dust-cap, and pulled it back out, gently. |
#8 |
I bought a pair of Boston Acoustics T-830s off the showroom floor of a local audio shop (that I was later employed at), and the dust cap for the midrange was pushed in. I tried the vacuum trick with no luck, so what I did was tore off a couple inches of duct tape. I pressed the duct tape firmly onto the dustcap without causing it to indent any further, then I simply tugged on the duct tape. The dustcap pulled right out, and I peeled the duct tape off.
Later on when I worked at the same store, I fixed MANY dustcaps the same way. It works great regardless of whether it's a soft dustcap like it was on my Boston, or a firm one like on larger woofers, because you can press as hard as you need to on the duct tape. |
#9 |
Five methods of restoring dust cap to normal shape.
1. speakers with vented pole pieces are good because you take a thin paint brush and push it through the vented pole piece and stroke back the dustcap with the brush. 2. use a very powerful/powerful vaccum cleaner with a small attachment,hold it and switch on[do not do this on tweeters or delicate midrange drivers]. 3. use some adhesive tape and stick to the dustcap and gently pull. 4. get a needle,make a small hole in the centre of the cone and push the dustcap back to normal position,then put a blob of glue on pin sized hole on dustcap to seal it up. 5. last resort,remove dustcap carefully and use old dustcap as a template to make new one out of 'sugar' paper or thin felt. |
#10 |
diyAudio Moderator Emeritus
Yes, I have to vote for the tape method too. It's worked for me on many occasion (again caused by a 2-3 year old - why do they find it so appealing!?!)
If it's an uncoated paper dustcap then I would be inclined to try the vacuum first.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
| My 2-year-old pushed in the dustcaps on my 12" ATCs | houstonian | Multi-Way | 20 | 23rd May 2007 10:48 AM |
| How far can a pair of SAP15 being pushed into a 4 ohm??? | Leolabs | Solid State | 5 | 16th January 2007 04:42 PM |
| Plastic cones or paper cones? | beppe61 | Multi-Way | 19 | 19th February 2006 11:37 AM |
| Help me please 12 inch pushed in centre | dodgy99uk | Multi-Way | 7 | 16th February 2004 10:54 PM |
| Help: Soft dome tweeter pushed in | Al Garay | Multi-Way | 46 | 8th October 2003 06:45 PM |
| Page generated in 0.10628 seconds (79.13% PHP - 20.87% MySQL) with 10 queries |
