Dynaudio Focus 110 and 140 Crossover Comparison Details - diyAudio
Old 15th January 2015, 02:12 AM   #1
Default Dynaudio Focus 110 and 140 Crossover Comparison Details
Hi All,
Good day, I know there are a lot of great talent here. So I would really appreciate your answers, feedbacks, and comments on the questions base on the attached Picture layout of both Dynaudio Focus 110 and 140 Crossover schematic.
Question:
1) Circuit of Varistor + L4 + 27uF + 10 ohm is a band pass or notch filter for the resonance frequency of the tweeter?
- I believe the varistor is the fail safe for the amp consider irregularity of electrolyte cap, is it correct?
- Consider the temperament of the electrolyte, what can we expect of the sound when dissipation factor is high or irregular?
- Can we perceive the midrange may have some harshness because of non linear behavior of the electrolyte?
2) Circuit 6.8ohm + 1.5uF is for the rising impedance of the tweeter in higher frequency?
- Sound wise, what can we perceive if we do not treat this rising impedance, considering the amp will not compensate?
- What is your opinion on the sound for well flatten rising impedance?
3) Can I consider the lattice filter of 2 pcs caps and 2pcs Inductors is theoretically to have no contribution to any additional resistance, capacitance, phase, or inductance to the tweeter + and -?
- Is the 10uF of the Focus 140 means a wider range of high frequency being subjected to this time delay? If not what is the increased capacitance do?
4) What is your opinion over the additional 22 ohm resistor(not in the Focus 110 crossover) in the crossover for Focus 140 over the Focus 110?
- Does it mean the Focus 140 trying to regulate 2 frequency peaks in the high frequency range after the 4.7uF 1st order cross?
- Is it better to flatten the impedance peak of Focus 140 using only 1 parallel resistor only instead of 2?
- Why do we need the additional 22 ohm resistor in the Focus 140 circuit?
Old 15th January 2015, 09:02 AM   #2
Lojzek is online now Lojzek  Croatia
Lojzek's Avatar
How do you know this is the schematic of said products?
There is still project data available for vintage Dynaudio DIY speakers
that employ almost the same filter solution with obviously different
part values.
Are you sure this is a varistor in series with RLC?
In general, your best way to learn what filter does in a circuit
is to simulate with a speaker.
RLC in parallel with amp out, flattens system impedance, does
not change FR. Resistors Rs and Rp define attenuation of tweeter.
What you call lattice and series cap shape response.
Nothing special and I would say unnecessary complicated.
Old 15th January 2015, 09:37 AM   #3
Tattoo's Avatar
Originally Posted by adrichia View Post
Question:
This is impedance correction.
The elco is not in series with the speakers and therefore has no audible influence on the sound.
The filter itself is a first order filter (L1 and the 4,7uF cap). If you perceive midrange hardness, that would be my suspect.
Its is indeed impedance correction. Its there so the filter can do what its supposed to do.
This is an allpass filter. It has a time delay effect.
The speakers use different mid bass drivers, so the allpass filter needs to be different.
Its a voltage divider, making sure the outputs of both drivers is the same.
If you search for X, than eventually you'll find X. Hopefully X is the truth.
Old 15th January 2015, 10:07 AM   #4
Lojzek's Avatar
the RC circuit in parallel with bassmid increases the steepness
of the LP filter and attenuates higher frequencies. There is no
midrange harshness with commercial Dynaudio products.
Old 15th January 2015, 10:18 AM   #5
Tattoo's Avatar
That RC circuit is impedance correction. It makes sure the filter can do what its supposed to do: Be a first order filter.
First order filters place a high strain on the tweeter witch could be audible? Just guessing here.
I have a very similar Dynaudio design (D28/2 and 17W75XL) and hear no midrange hardness.
Old 15th January 2015, 11:23 AM   #6
system7 is offline system7  United Kingdom
system7's Avatar
Breaking down a complex crossover involves some modelling usually. I did something similar to a B&W Matrix 3:
Could a kind soul please break down this horrid Xover
You have a well behaved 4 ohm (?) polycone bass with a simple ca. 1mH coil and Zobel. Only a few 5-6" woofers will respond to this simplicity, but Dynaudio and Morel are two examples that work.
That crisscross lattice tweeter filter is a standard sort of old group delay equaliser, but interestingly, a simple shunt coil does much the same thing. The filter is also found on the Zaph|Audio - ZD5 - Scan Speak 15W8530K00 and Vifa XT25
So what you have there is second order electrical filters at heart with RC driver impedance correction and some overall LCR crossover impedance correction. And some tweeter attenuation. The Zobel works with attenuation on the tweeter to increase the top-end rolloff. A good Dynaudio archive here:
Dynaudio archive
I would guess the overall acoustic filter is BW3.
Best Regards from Steve Ponsford in Portsmouth, UK.
Old 15th January 2015, 11:32 AM   #7
Tattoo's Avatar
I see only a first order filter, but I can be wrong.
What are the parts that make up the second order filter?
Old 15th January 2015, 12:19 PM   #8
system7's Avatar
On the bass, the Zobel-type RC circuit adds the second order electrical element to the first order coil. It effectively damps the voicecoil too.
On the tweeter, the lattice filter adds an inductance to the first order capacitor.
It's certainly not 6dB/octave overall rolloff. That would sound terrible. But really, it's the wrong way to look at it. You combine the electrical filter with the mechanical filter of the drivers to get something reasonable like 12-18dB/octave rolloff and do your thing with phase alignment, however it works out. The example 5" Dynaudio 15 W-75 has considerable internal damping and very low inductance. A unique sort of driver.
You can see how a second order bass/third order tweeter filter is best combined with natural rolloff below.
File Type: png Natural Response versus Filtered response.PNG (19.8 KB, 167 views)
Old 15th January 2015, 12:39 PM   #9
Tattoo's Avatar
I understand what your saying, but I'm not convinced.
If I have time, witch atm I have not, I'll do some measurements and see what the electrical filters are.
I agree on the mechanical+electrical filters stuff.
Old 15th January 2015, 01:16 PM   #10
Hi guys,
Thanks a lot for the responds. But will be grateful if you answer the questions in my 1st post. Only Tattoo did answer some of my queries that I am looking for. Sorry for be straight forward, don't mean to be rude.
Crossover (Network) schematic details for Rogers / Chartwell PM510 (LS 5/8) darkmatter Multi-Way 3 26th August 2014 10:26 PM
Dynaudio Focus 110 Xover Upgrades larevoj Multi-Way 9 23rd September 2013 07:26 PM
Legacy Focus Crossover swantzilla Multi-Way 0 11th February 2013 03:16 PM
Looking for Dynaudio Focus 140 crossover schematic Joostp Multi-Way 10 28th November 2012 09:25 PM
3 Way crossover details... Lambo240z Multi-Way 310 22nd October 2011 08:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
