Combining -ve lead for speakers? - diyAudio
Old 12th January 2015, 10:07 AM   #1
Question Combining -ve lead for speakers?
Would there be any problems associated with combining the -ve signal leads from two pair of speakers (not joining left and right) - i.e.
Amp Left -ve to Left speaker 1 and Left speaker 2
and
Amp Right -ve to Right speaker 1 and Right speaker 2
The +ve leads would be routed through a double gang two way light switch.
This is a temporary measure to allow quick and dirty comparison between two pairs of speakers - IT IS NOT INTENDED AS A PERMANENT SETUP.
Old 12th January 2015, 10:30 AM   #2
Did it Himself
richie00boy's Avatar
Yes no problem at all.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more.
Old 12th January 2015, 12:19 PM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
As long as your amplifiers are not working in bridge mode and the -ve lines are the same at the source.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 12th January 2015, 01:13 PM   #4
Did it Himself
I read it as only one amp is used, he's just switching speakers.
Old 12th January 2015, 11:02 PM   #5
Correct, a single bog-standard Quad 303 driving one of two pairs of speakers as selected by a double gang two way light switch switching the +ve signal leads.
Both pairs of "left" -ve leads will be combined and both pairs of "right" -ve leads will be combined.
Old 13th January 2015, 01:59 AM   #6
Greebster's Avatar
Then he would require a DPDT switch. Alco Switch have some nice ones. Have a few here that are center off latching type. Pull out to change position.
Old 13th January 2015, 08:00 AM   #7
Did it Himself
He is using a DPDT switch...
Old 13th January 2015, 09:00 AM   #8
Actually, strictly speaking I am using a pair of single pole double throw (SPDT) switches - i.e. where I am evaluating Speaker Pair A and Speaker Pair B, I could set the switches such that I am listening to Speaker Pair A Left and Speaker Pair B Right.
With a DPDT switch I would have to listen to Left & Right Speakers A -or- Left & Right Speakers B.
Old 26th January 2015, 01:37 PM   #9
Well, I made up the crude DIY speaker switch as described in the opening post and it works absolutely fine
Old 26th January 2015, 03:25 PM   #10
giralfino's Avatar
I cannot think of a valid reason you need to listen to Speaker Pair A Left and Speaker Pair B Right, except maybe for comparing absolute SPL.
Anyway, the problem I see in using a switch like yours is the contact resistance, it can be some ohms, not a problem in the intended application, but a problem when driving a speaker, as the effect is not constant with frequency.
Ralf
Combining 2 speakers together. mrc6064 Construction Tips 9 16th March 2011 12:44 AM
Combining 2 speakers (possible?) burchill Multi-Way 4 23rd June 2008 11:00 AM
Sonic impact, which power lead is +ve? gilbodavid Class D 2 3rd November 2005 06:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
