I got all excited.....
Old 25th January 2004, 12:27 AM   #1
Konnan101 is offline Konnan101  United States
Send a message via AIM to Konnan101
Default I got all excited.....
I just recently found an old pair of mirage 360's that my dad had. When i went to listen to em though, one of the speakers was blown, when i looked under the screen and looked at the speakers I noticed the midwoofer, was all torn up. Half of the surrounding foam was ripped. I tried to find some way to get these speakers open to mayb replace the drive, but was unable too.
Anyone have any suggestions on how to open the box.
also does anyone know the specific drivers that the mirage 360's use. so if at the very leats i can use the drivers here build a new box and maybe replace the midwoofer.
thnx a bunch
Old 25th January 2004, 03:50 AM   #2
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
OK, Your best bet if the mid surrounds are torn is to get a kit to replace the surround, not the entire driver. They usually cost about $25 for a kit for 2 drivers. This is assuming that only the surrounds are damaged -not the cones. This will be mightily cool- you get some great speakers for $25 and a bit of work.......don't know how to get the grille off though.....
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 25th January 2004, 03:56 AM   #3
Yeah i had thought about replacing the foam, but cant seem to get the drivers out of the box, and i definatly dont wanna break the box. Anybody had any experience with these speakers and possibly removing them.
Also i think the foam has completely come off of the cone, like the foam surround isnt attached anywhere on the cone (they have been sitting a long while).
Old 25th January 2004, 04:53 AM   #4
diyAudio Editor
Variac's Avatar
The foam coming all the way off is still OK. I wish I could help with advice on removing the grilles. Maybe a putty knife inserted and twisted... Changing to a new driver the same as the old will probably be pricey IF you can find it- replacing it with a similar driver will screw up the response big time.
Old 25th January 2004, 01:30 PM   #5
I was actually fooling around with it last night and i got this foam piece off (not the speaker foam) and under it were all the screws to release the driver. So that problem is solved, now i just need ot get a refoaming kit.
Thnx for yalls help
Old 25th January 2004, 01:33 PM   #6
i got one problem though, when i removed that foam thing ( which i assume is the gasket, there is a layer of like hard plastic like foam stuff and some old dried up glue. Do i need to scrape all this off until i get to the metal or should i just scrape the glue off, cause this little piece above the metal holds the foam up about a qurter inch, and seems like it would mess the speaker up if i removed it.
And also i am reading a thing on refoaming and it tells you o remove the dustcap, whats the importance of this?
thnx
Old 25th January 2004, 02:00 PM   #7
On Hiatus
SY's Avatar
You generally take the dustcap off to get access to the voice coil. During the refoaming, you need to keep the coil centered around the magnet's pole piece using shims. Once the foam is attached and the glue dried, you then remove the shims and glue on a new dustcap (or the old one if you didn't beat it up too much while removing it).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
I got all excited.....Hide this!Advertise here!
i'm excited ucla88 Multi-Way 2 15th February 2002 09:08 PM
