My DIY Horn setup
Thank you! Horns are fun, no doubt!
Lego for big boys.
Completed set. Later had the nuts replaced with furniture caps for a smoother look.
It would be more expensive to do them over in any material;) seriously though, I did not pay much for the job and aluminum looks way better than plywood. I did not go for aluminum because of the strength, at least not for now. Should I go for a larger ALE driver the case might be different;)
Thank you!
At last, the 3-way satellite was up and running.
Here seen with the prototype en baffle bass units I initially had plans of finalizing to go with a 2-way horn sattelite. Since I later went ahead with the midbass horn, I saw the opportunity to build something quite different. I had earlier assisted in designing and building a huge SLOB with a friend and DIY mentor, and a plan started emerging.
