I have the vifa logic BC14SG49-4 and AC25SG05-4. I was going to attempt to replicate the Madisound swifty speaker kit. But the kit used the 8 ohm version of the midwoofer. The differences seem to be too much to try and re configure the kits x-over. I found an x-over for these drivers. But it seems odd to me. It appears to have no damping for the tweeter. There is a 7db difference in spl between the woofer and tweeter.
http://www.chyna.wz.cz/audio/index.htmlWill this work ?
Not too sure about that xo in link. The phase seems way off and you're right, there's no tweeter attenuation although a 5-10ohm resister in line before the HP filter would be a simple starting point.
As far as the swifty goes, Just cut the inductor in half and double the cap on the woofer circuit to accept the 4ohm model and it should be very close.
David
David
Are we looking at the same crossover schematic?there's no tweeter attenuation although a 5-10ohm resister in line before the HP filter would be a simple starting point.
David
This is the one:
www.chyna.wz.cz/audio/efekty/vyhybka.png
Yes that is it. But I can't figure out what he is doing. Though he does appear to know what he is doing ?Are we looking at the same crossover schematic?
This is the one:
great way to fry an amp, use a proper L pad: L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker voltage divider - sengpielaudio Sengpiel Berlin
http://www.madisound.com/pdf/swifty.pdf Yes, I can not understand why he would do the attenuation that way. It just seems unnecessarily complex and costly.But this x-over looks to be less complex than the swifty x-over.
But this x-over looks to be less complex than the swifty x-over.[/QUOTE said:A bit but a few resisters are cheap, and the LP circuit is simpler so a bit of a wash.
Just do as blue934 suggests: double the cap and halve the inductor. This is a LR2 @ 1600. As to the tweeter attenuation, this post explains it.
http://www.diyaudio.com/forums/multi-way/114916-replace-crossover-existing-box-3.html#post1394839
amt
amt
L-pad is a bullet-proof solution, but capacitor parallel to the tweeter is not necessarily a way to fry the amplifier (although I personally would put a 2R2 ohm resistor serially to that capacitor). Simulation on the link show more than 5 ohm at 20kHz, so it has plenty of reserve at higher frequencies.great way to fry an amp, use a proper L pad
- vifa logic x-0ver
