vifa logic x-0ver
vifa logic x-0ver
Old 28th December 2014, 04:29 AM   #1
ton def is offline ton def  United States
Default vifa logic x-0ver
I have the vifa logic BC14SG49-4 and AC25SG05-4. I was going to attempt to replicate the Madisound swifty speaker kit. But the kit used the 8 ohm version of the midwoofer. The differences seem to be too much to try and re configure the kits x-over. I found an x-over for these drivers. But it seems odd to me. It appears to have no damping for the tweeter. There is a 7db difference in spl between the woofer and tweeter.
http://www.chyna.wz.cz/audio/index.htmlWill this work ?
Old 28th December 2014, 07:03 PM   #2
anybody ?
Old 28th December 2014, 07:35 PM   #3
blue934 is offline blue934  Canada
blue934's Avatar
Not too sure about that xo in link. The phase seems way off and you're right, there's no tweeter attenuation although a 5-10ohm resister in line before the HP filter would be a simple starting point.
As far as the swifty goes, Just cut the inductor in half and double the cap on the woofer circuit to accept the 4ohm model and it should be very close.
David
Old 28th December 2014, 07:45 PM   #4
Sonce is offline Sonce  Macedonia
C2051 attenuate the tweeter. Crossover seems to be OK.
EDIT: hmm... on the second look, "position" and "relative distance" are 0 mm both for the midbass and the tweeter. Maybe simulation is not the correct one, regarding the actual position of the drivers.
Old 28th December 2014, 07:49 PM   #5
David
Are we looking at the same crossover schematic?
This is the one:
www.chyna.wz.cz/audio/efekty/vyhybka.png
Old 28th December 2014, 08:20 PM   #6
This is the one:
Yes that is it. But I can't figure out what he is doing. Though he does appear to know what he is doing ?
Old 28th December 2014, 08:43 PM   #7
blue934's Avatar
Yes, that's the one I was looking at. I've not seen a parallel cap used for attenuation before but if it works, I stand corrected.
David
Old 28th December 2014, 09:07 PM   #8
PeteMcK is offline PeteMcK
great way to fry an amp, use a proper L pad: L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker voltage divider - sengpielaudio Sengpiel Berlin
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 28th December 2014, 09:49 PM   #9
http://www.madisound.com/pdf/swifty.pdf Yes, I can not understand why he would do the attenuation that way. It just seems unnecessarily complex and costly.But this x-over looks to be less complex than the swifty x-over.
Old 28th December 2014, 10:04 PM   #10
blue934's Avatar
[QUOTE=But this x-over looks to be less complex than the swifty x-over.[/QUOTE]
A bit but a few resisters are cheap, and the LP circuit is simpler so a bit of a wash.
vifa logic x-0verHide this!Advertise here!
74HC logic or No logic feedingthe Interface Receiver. Mario_JR Digital Source 2 10th July 2011 08:18 PM
XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM knightat83 Multi-Way 6 24th January 2009 08:51 AM
PA speaker X-0VER oquela PA Systems 9 29th August 2007 01:37 AM
74AC logic V.S. 74HC logic ? fastcat95 Digital Source 0 16th December 2006 03:03 PM
What happened to Logic by Vifa? sardonx Multi-Way 1 19th January 2006 11:32 AM
