Can two drivers be wired series and inverse phase?
Yes.....Cardoid. Instead of sacrificing efficiency by using a single driver's back wave, plan to use a second driver as in a dipole
Yes it's works..
I call it Dual Acoustic Dipole.
http://www.diyaudio.com/forums/full-range/253992-true-dipole.html
With Fostex FE126eN :
attachment.php
Using with H frame, Xo near 200 hz :
attachment.php
Axis at listening point (3 m) :
attachment.php
Phil.
Yes it's works..
attachment.php
attachment.php
attachment.php
Phil.
Interesting. Do you have sensitivity measurements? I did try such a setup but compared to "normal" one pointing forwards and one backwards but above and below each other I lost a lot of sensitivity, about 6 dB so distortion was far higher.
Or rather, I lost sensitivity if I damped between the drivers which I had to as I got an on axis null if I didn't. I suspect it is because the rear driver passed through the cone of the other driver. In my case I used shallow 6.5" drivers so the null was between ~ 600 - 1000 hz.
