F3 responce, Shelf Filter
Old 21st December 2014, 11:12 PM   #1
rich31td is offline rich31td  United Kingdom
Default F3 responce, Shelf Filter
Out of curiosity, if I had a sealed speaker that measured Qtc=0.707, F3=150hz and I wanted to impliment a simple shelf filter to extend the F3 responce down one octave to 75hz in MiniDSP, would the following be correct?
1 octave;
FC= SQRT (75*150) = 106hz
Gain=12dB
Q=0.707
1.5 octave;
FC= SQRT (56.25*150) = 91.8hz
Gain=18dB
Q=0.707
2 octave;
FC= SQRT (37.5*150) = 75hz
Gain=24dB
Q=0.707
If the speaker measured Qtc=0.5 would the above also be correct if I changed the Q of the filter?
F3 responce, Shelf FilterHide this!Advertise here!
Need an Active 2nd Order Low Shelf Filter aka Low Shelving Filter elmura Analog Line Level 13 28th April 2013 03:15 PM
Preamp mod with a low cut shelf filter johanwahlberg Analog Line Level 11 11th December 2012 04:18 PM
variable frequency tilt/shelf filter - bad idea? mt490 Analog Line Level 2 29th December 2010 06:12 AM
OK to run an RC filter on the output of my F3? skaelin Pass Labs 2 16th October 2009 03:04 PM
Passive Shelf Filter Tenson Multi-Way 19 17th July 2006 09:13 PM
