Could somebody check this XO Please? - diyAudio
Old 18th December 2014, 04:28 PM   #1
ODougbo is offline ODougbo  United States
Default Could somebody check this XO Please?
This was a pre-made board and something seems fishy here. Could somebody check this please?
In particular the woofer circuit path:
IN bottom right, through the large coil, then terminated to the .22 smaller coil - then out
The speaker project is a 2-way - 832592 (8ohm) & MDT20
Other info: white coil is 16gauge sidewinder - smaller black .22 16gauge sidewinder
Old 18th December 2014, 04:49 PM   #2
dragonweed's Avatar
Without knowing the schematic and the woofer (832592?) it is pretty difficult to tell anything about your XO......
Old 18th December 2014, 06:15 PM   #3
Scottmoose's Avatar
Pass. Need to know the drivers + their impedances & frequency response as mounted on the baffle. Without that, it's just flailing in the dark.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 18th December 2014, 06:32 PM   #4
Lojzek is online now Lojzek  Croatia
Lojzek's Avatar
It appears your LP filter is a 3rd order electrical with a C in series with R.
Caps 10uF +12uF look to be in parallel with RC. I could very well be wrong
about it.
L1=0,85 mH
R=8 ohm, C=22uF
L2=0,22 mH
Old 18th December 2014, 09:24 PM   #5
OHHH Third Order - was comparing it to a 2nd. Never would have guessed that!
No schematic, it would be nice to have one, was going to try to sketch one up.
Attached PDF for the WR130; never knew why they stopped making it, affordable, easy to work with....
Thank you.
Old 18th December 2014, 10:10 PM   #6
Assume this is the tweeter?
Morel MDT-20 1-1/8" Soft Dome Tweeter
Old 18th December 2014, 10:29 PM   #7
Yes that is the tweeter.
The story is my friend upgraded their system and returned the speakers/boxes to me and now have a second chance to rebuild them.
Leaning to a 10 liter, rectangle box.
Old 20th December 2014, 01:43 PM   #8
Dissi is offline Dissi  Switzerland
I'm not sure at all if the attached schematic is correct, but it looks like a 2 kHz crossover without any baffle step correction. No bass and too much mids and heights?
Old 21st December 2014, 11:39 AM   #9
Thank you Dissi!
The 22uf (10uf & 12uf) is curious, why didn't they use two of the same 22uf caps.
Three caps to ground that seems like a heavy load for a woofer that is known for a smooth response.
Tweeter circuit - it's a L-pad I think; there's a hidden 2.5ohm resistor behind the coil.
The bass may be lacking, it was screaming at me when I disconnected it, but that was only for a few seconds and this was now a Salvage Operation.
So yesterday went for it, ran the whole box through the saw and cut off the front baffle and started over. This time with felt lining, close tolerance driver recesses, moved the port and rounded over all the edges.
Old 21st December 2014, 03:24 PM   #10
Finished it up and listened - oh boy it's awful.
Really thin, cold, predominate mid-range.
Even checked the tweeter in case it was not working - but fine (not blown).
Digital XO vs Op-amp XO, which would be best to use in active speakers? MikeHunt79 Analog Line Level 11 16th November 2009 06:06 PM
Please help check my XO (Humble Optimo) dublin78 Multi-Way 2 24th February 2009 11:48 PM
XO sanity check for newbie avizandum Multi-Way 2 30th December 2007 09:29 PM
Please check this xo for me kifeinthesink Multi-Way 1 3rd January 2006 09:14 PM
1st Order XO with -6dB XO frequency. Has anyone tried this? primalsea Multi-Way 20 28th May 2004 07:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
