4th order crossover ??? - diyAudio
Old 15th December 2014, 10:58 AM   #1
Default 4th order crossover ???
Is this 24db/octave at 380hz
Just curious
thanks John
Old 15th December 2014, 11:02 AM   #2
Inductors are
2.4mh
1.2mh
thanks John
Old 15th December 2014, 11:22 AM   #3
Sonce is offline Sonce  Macedonia
It might be, if it is low-pass filter only.
Old 15th December 2014, 02:03 PM   #4
It is impossible to say because coils/caps values are dependent not only on the crossover frequency but also on the impedance of the driver (which is not constant). Moreover in speaker crossover what is important is the ***acoustic*** slope and not the electrical one. The acoustic slope depends also on the frequency response of the driver. If you search for some well documented projects you'll find that often it is possible to achieve a 4th order acoustic slope with only 2 elements.
Ralf
PS Not related for your question, but based on the photo the coil placement is not ideal. See: Placement of coils in crossover networks
Old 15th December 2014, 02:08 PM   #5
reverse engineer the crossover and post the schematic.
regards Andrew T.
4th order butterworth/linkwitz passive crossover jayam000 Multi-Way 18 11th June 2010 04:03 PM
LR 4th order vs LR 8th order crossover redliner Subwoofers 1 8th January 2009 12:32 AM
Another 2nd/4th-order L-R active crossover johnf Solid State 6 7th April 2005 11:16 AM
Elliptic crossover ( greater then 4th order LR) Hybrid fourdoor Multi-Way 11 6th November 2004 05:06 PM
Definition of 4th order acoustic crossover moving_electron Multi-Way 4 8th April 2004 01:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
