Old 22nd January 2004, 09:23 PM   #1
sobazz is offline sobazz  Denmark
sobazz's Avatar
Unhappy Confusion has occupied my head!
D***... I downloaded Speaker Workshop today. Normally I model drivers in WinISD, but SW is a more comprehensive solution and I'm about to measure response on some small speakers I've made, for which SW seems brilliant.
In order to get to know the program I entered the data for the midbass driver used, a Vifa TC11SG, and modeled the frequency response with the same enclosure and port data.
But the response computed by SW is very different from WinISDs. Instead of an almost flat response around 70hz I got a 5db peak at 80hz! Why?
I've confirmed the parametres several times, but they are exactly the same as the ones used in WinISD.
Old 22nd January 2004, 09:33 PM   #2
SY's Avatar
Is there a difference in the assumed box loss parameter (QL)?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 22nd January 2004, 09:57 PM   #3
sobazz's Avatar
No. I changed that the WinISD values too. By the way... it has suddenly changed to the worse... now I have a peak of 8db at 145hz and a rolloff below 0db from 115hz... I cannot see what I've done!?
WinISD first:
Old 22nd January 2004, 10:03 PM   #4
sobazz's Avatar
Ehh.. sorry about the freq. response range.
Here's SW
Old 22nd January 2004, 10:07 PM   #5
Sad but true, freeware is not always accurate,
they don't have to be.
I don't know the answer to this but;
the secret to using freeware is what it does right.
All freeware is extremely limited compared to the
professional products, simply thats the way it it is.
WinISD is simplistic but AFAIK never too far wrong.
SW claims a lot more than it can deliver, IMO.
sreten.
Old 22nd January 2004, 10:13 PM   #6
sobazz's Avatar
Huh.. I thought the formulars used were pretty standard formulars for calculating speaker response with T/S.... Arghh...
Old 22nd January 2004, 10:16 PM   #7
sobazz's Avatar
Another reason why I dislike Speaker Workshop: it's interface is extraordinarily inefficient...
Old 22nd January 2004, 10:24 PM   #8
A port length of ~ 6" and ~ 2.8 " diameter is not for an 1/8 cuft box.
you may have your radii and diameters confused.
sreten.
Old 22nd January 2004, 10:31 PM   #9
sobazz's Avatar
No way. 6" = 150mm is ok. The same in WinISD for Fb = 68hz. The port diamter is 1.378" (and not what you wrote) = 35mm. The box volume 1/8 ft^3 = 3.5L.
All of the above is perfectly ok.
Old 22nd January 2004, 10:39 PM   #10
Send a message via MSN to officeboy
no, in Speaker workshop, the port RADIUS is 1.378"
Kit Confusion! deadparrot Chip Amps 6 28th May 2009 08:52 PM
motor types head to head for a TT p_ete2003 Analogue Source 20 11th January 2007 08:29 PM
mox confusion cowanrg Solid State 10 9th August 2005 11:11 AM
More(l) confusion mr_push_pull Multi-Way 2 29th May 2005 04:54 PM
I2S confusion MWP Digital Source 2 9th November 2002 10:36 AM
Page generated in 0.10626 seconds (81.13% PHP - 18.87% MySQL) with 11 queries
