I have four Dayton 8" drivers that I’ll be building a Dayton 8 type setup with. All the drivers have been broken in, and I’ve tested them with Speaker Workshop so I now have some numbers to play with.
My question is, for designing the box, should I just take the average of all the drivers and use that for box design? And then how should I pair them? Code:
Driver A Driver B Driver C Driver D Avg 31.317 32.84 34.863 32.892 Fs 32.978 1.123 1.347 1.269 1.333 Vas 1.268 0.424 0.441 0.501 0.445 Qts 0.45275 2.762 3.195 3.586 3.351 Qms 3.2235 0.5 0.511 0.582 0.514 Qes 0.52675 0.57 0.55 0.575 0.589 Le 0.571 1.179 1.203 1.225 1.228 L1 1.20875 43.559 48.891 44.2 44.353 R1 45.25075 Any suggestions? Code:
A+C %/avg B+D %/avg 33.09 100% 32.866 100% 1.196 94% 1.34 106% 0.4625 102% 0.443 98% 3.174 98% 3.273 102% 0.541 103% 0.5125 97% 0.5725 100% 0.5695 100% 1.202 99% 1.2155 101% 43.8795 97% 46.622 103% Avg of Avg 99% 101% |
#2 |
Qes on driver C looks more than suspect to me, so Qts does as
well. I'd recheck this, possibly a poor connection, if its still the same possibly a poor connection in the driver, resolder the terminals. If that doesn't work you effectively have a "reject" unit. You should use the average of all drivers for box design, theorectically. But you have to come to terms with the accuracy of your measurements. I'd suggest taking your measured results and adding some bias towards the measured specs by Parts Express and in the Dayton 8 design. |
#3 |
Thanks, I've got some new cables coming and I'll be recalibrating and retesting with them. (one connection is a bit sketchy)
I'll also take my average and Parts Express' numbers and use that average of the average to pick the best box setup... And what about the QTS makes driver C a "reject"? Is a higher number there bad? And can you tell this is my first time to do this?
| Matching drivers...beyond the specs | smokinghot | Multi-Way | 4 | 28th January 2009 10:41 AM |
| drivers matching | bigpanda | Solid State | 9 | 13th May 2006 04:15 PM |
| Matching a new tweeter to existing drivers | Dr.H | Multi-Way | 4 | 22nd March 2005 06:43 PM |
| 2-way audiophile-grade box - need matching drivers together | Vortex | Multi-Way | 10 | 27th December 2004 05:38 PM |
| Matching Drivers? | Scribble | Multi-Way | 8 | 11th January 2003 03:47 PM |
| Page generated in 0.07097 seconds (74.45% PHP - 25.55% MySQL) with 10 queries |
