Since the two midwoofers have about the same width as the horn, the horizontal dispersion of the midwoofers can be made to match that of the horn (which is good). But the vertical dispersion of the midwoofers is too wide, because they are small in that direction.
A single, bigger midwoofer will be a better match for the horn. You could also run the upper woofer up to 1 kHz and let the lower woofer only handle bass (2,5 way)
