JBL L300 DIY for Newbies - diyAudio
Old 2nd December 2014, 06:34 PM   #1
Default JBL L300 DIY for Newbies
Recently I decided to build my L300 clone project, that's not the first attempt, some time ago I build one with a 2215 woofer and couple of scan speak drivers (8545 mid and 6600 illuminator tweeter) but the result as not as expected.
Now I have bought some good drivers, the JBL 2420 mid with 2307 horns and the 2405 tweeter, and the Nelson PASS components for the crossover at Madisound,
I was wondering about the 2215 woofer, it's a LE15A professional version with 8 ohms, do I have a lot to expect if changing to a 2235H?
There is a pair at ebay for selling from a guy from Hungary, but it does not seems very in good shape compared to the other components, also the cones are different.
Two JBL 2235 H Woofer 2 Stuck Refoamed by Pro for JBL 4343 JBL 4335 4353 4430 | eBay
Nelson Pass L300 crossover.
Old 2nd December 2014, 06:47 PM   #2
The speakers are with a hole in the bottom, this I made to increase de cubic feet required for the 2115, but I pretend to remove the hole inserting a 1 inch base of MDF,
They were also used without passiver crossover, I used a DCS2496 with 6 mono amps.
They are not too ugly boys...
I will made the bracement as the originais, 2 in each panel horizontally and 2 at the rear panel vertically, with 1 x 2 1/2 inch woods, like this I saw at audioheritage forum
The question is should I consider buying these 2235? The 2215 doeas not do the job?
Also I would like to hear some tips and opinions about this project.
The base I will remove and let them with the L300 original size.
JBL L300 rebuild Dappmag Multi-Way 4 15th January 2014 04:03 PM
JBL L300 lpd Swap Meet 4 22nd February 2013 10:43 PM
JBL L300 for sale stuhaugen Swap Meet 2 25th April 2006 06:46 PM
JBL l300 kekropas Multi-Way 7 9th April 2006 09:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
