Old 22nd January 2004, 02:18 AM   #1
asauer is offline asauer  United States
Send a message via MSN to asauer
Default Choosing Woofers for Horn Enclosures
I would like to build a cheap and easy horn to see how they perform. I'd like to know what qualities in drivers (as far as T/S parameters go) that should be looked for, and any possible EASY designs. Size is of little concern, and I'd like deep bass extension...which I know small horns will not produce, so any size is fine so long as it gets the job done.
I'd like to spend under $100 for a driver...so choices are extremely limited I'm sure.
Old 22nd January 2004, 04:43 AM   #2
Eminence LAB 12 is made for horns. It has similar specs to the Shiva, but that is secondary to the aim of using it in a horn enclosure. Available Parts Express, although for something over $100. It also has a website devoted to using this in a horn.
Eminence also makes the HE-10, a 10 inch version of the LAB 12. Don't know if Parts Express has that yet-it's brand new. You can check the specs out at www.eminence.com .
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 22nd January 2004, 11:58 AM   #3
Actually LAB12 is really too low Fs for efficient horn use, and it's new 10" version seems to require a small throat which translates to very long horn path to get decent mouth area.
Best approach seems to be to select a driver with Fs around an octave or less HIGHER than the lower cuttoff of your horn. Horn loading will effectively lower the driver's Fs, and matching these values will produce a more even response. Therefore, if you want a 30Hz horn, select a driver with Fs around 45Hz to 50Hz. As far as other parameters are concerned, easiest way is to simulate in program such as David McBean's Hornresp, and fiddle with various values.
Cheers
PS. don't be afraid to try cheap drivers - the results may surprise you!
Old 22nd January 2004, 05:15 PM   #4
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
I Agree 100%
People fail to realize, that the Lab 12 was designed for the
Lab Sub. The Lab Sub is 45 inches in depth. So, when using
a long horn you can use a speaker like the Lab 12.
Cheers
Exactly!
One of the many fogotten facts of having the speaker
interact with the length of the horn, and, enclosure size.
Frankly, the easiest horn to make would be the Altec A 7,
or the JBL 4530{Scoop}. Unless, of course, your
woodworking skills are, impeccable.
OMNIFEX
Old 22nd January 2004, 08:48 PM   #5
Speakerholic
Cal Weldon's Avatar
Default Altec cabinets
Remember the A7 cabinet was designed for volume, not necessarily deep bass. They work great but they are really intended for PA use in small venues. If you are interested, go to eBay item # 3073191806. These are Altec knock off cabinets.
In my 828 [original plywood] boxes I put a:
Selenium WPU 1507 QCF [for high humidity] woofer, although the WPU 1505 is good if they are kept inside.
Selenium 205Ti mounted to an Altec 511 horn.
Passive 2nd order crossover plus resistors on the tweeter.
I run it with a bridged Carver cube on each side.
Good and very loud
If you need more info, let me know
Cal
Old 22nd January 2004, 08:52 PM   #6
Speakerholic
Cal Weldon's Avatar
Default If you want to get really silly
Now if you lust for large...
Cal's big speakers
Do what I did, GO WILD
Cal
Old 22nd January 2004, 10:10 PM   #7
OMNIFEX's Avatar
Cal those are classics.
Actually, the A 7 uses the same principal as your 210's
You can tune the reflex chamber to achieve lower bass
notes, by adjusting the Panels.
OMNIFEX
Old 22nd January 2004, 11:22 PM   #8
Speakerholic
Cal Weldon's Avatar
Default My A4's
Thanks Omnifex,
Yes those A4's are real beauties. I just wish they could go to a good home and be used more. I store that whole system outside.
I think I'll leave the port panels, they are tuned to 50Hz aren't they?
The cabinets on top are a system in themselves. The multi-coloured flared horn bass ports were my doing and I would guess their tuning to be around 50Hz as well.
She rocks!
Cal
Old 23rd January 2004, 05:57 AM   #9
mikee12345's Avatar
i like the lab12 for modeling horns.
the lab10 is odd,it seems like eminence lost the plot with this one.
i find 8-12" units with specs that usualy let them run in small boxes help= large rear chambers are annoying to accomodate into folded designs and just cause the horn to be larger.
Centauri said it -higher Fs than u might imagine!
check the partsexpress.com speakers...
my 8" horn goes fine,with 3.5mm xmax,certainly adaquate in the house!
the program ML UTIL will tell you ideal horn specs=but isnt easy to use,and ONe of the specs im unsure of what to input
Cheers
http://homepages.paradise.net.nz/quadroph
Choosing Amps for a 5 Way Active Horn System KCCT82 Pass Labs 32 26th April 2009 12:21 AM
Need help choosing a driver and a horn design. italynstylion Full Range 27 10th February 2009 12:28 AM
Need Help with choosing Nagaoka-Style Horn Monte Verdi Multi-Way 1 28th October 2008 09:37 PM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Page generated in 0.11856 seconds (81.83% PHP - 18.17% MySQL) with 10 queries
