Beyma TPL-200H
Beyma TPL-200H
Old 2nd April 2016, 06:51 PM   #21
enzoastro is offline enzoastro  United Kingdom
Is there a chance that what you miss with the compression drivers is distortion? Low distortion drivers always sound quieter running at the same db to me, a little distortion on some music sounds good too :-)
Old 2nd April 2016, 07:49 PM   #22
System215 is offline System215  Canada
Originally Posted by Adhoc1 View Post
Thanks for the info. Too bad your first crossover try just cost you money. Still, I think such info may be just as valuable as successes for those who are thinking about similar builds.
As you run it now with Kranis’ new filter, is it with decreased volume as sealed or ported box with a changed higher tuning?
As of right now, the box remains just as I built it—about 2 cu. ft. with a port tuned to around 45 Hz. Kranis suggested there were a number of solutions: (1) make a new, larger box with appropriate box tuning; (2) seal the existing box (to simulate this, we stuffed the ports with foam damping material); (3) reduce the length of the existing port to raise the tuning frequency to circa 60 Hz; or (4) keep the box just as I made it, but run it full range; that is use the electronic crossover only as a low pass for the 18" subs.
Kranis's measuring equipment and our ears agreed that solution (4) yielded a smooth integration of the 12" AE and the 18" Eminence, but only if we used a 12 dB/oct. L-R low pass filter, as a 12 dB/oct. Butterworth filter produced too much mid-bass output. More to save time and money than anything else, I opted for the "full range" solution.
At some point I mean to try the other solutions to see which yields the best results, but right now I'm enjoying the speakers too much to bother!
Hope this clarifies exactly what I did. . .
Regards, Joel.
Old 4th April 2016, 02:32 PM   #23
Adhoc1 is offline Adhoc1
Yes it did. An idea could be to seal the ports and add closed cell styrofoam to decrease the volume and try them out as sealed cabinets at around 0,75 ft³, if your sub works well up to about 110 Hz. (A block of 1,25 ft³ is easy to fix, then breaking it apart so the scrap material fit into the cabinet.)
Old 12th July 2016, 03:26 PM   #24
manninen is offline manninen  Finland
manninen's Avatar
http://www.homecinema-fr.com/forum/r...es/file/157465
French guys had tested tpl200h
Old 12th July 2016, 08:46 PM   #25
Face is offline Face  United States
Face's Avatar
Originally Posted by manninen View Post
"You can not view, download or attach files from this site."
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 13th July 2016, 01:30 AM   #26
chrapladm is offline chrapladm  Australia
^^^^^Same for me also.
I am curious to know if he 200 offers anymore usable frequency range over the 150. I know it can take more power so I am hoping that this means maybe it can sound better at home at a lower XO.
Old 13th July 2016, 04:15 AM   #27
manninen's Avatar
sorry don´t know what happened
homecinema-fr TPL200h test
Old 13th July 2016, 04:48 AM   #28
Face's Avatar
Thank you.
Old 13th July 2016, 06:07 AM   #29
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Thanks!!
(For comparison with CD)
flesh flash flush
Old 14th July 2016, 03:15 AM   #30
frangus is offline frangus  Australia
Not very useful to compare a midrange driver to a tweeter
Good measurements though
Beyma TPL-200HHide this!Advertise here!
Beyma TPL-150 dziemian Swap Meet 1 18th September 2014 06:44 PM
WTB: Beyma TPL-150 or TPL-150H NYCOne Swap Meet 0 9th July 2012 04:09 PM
TPL-150H vs WL3 (Beyma) ? Bigun Multi-Way 1 25th June 2012 07:38 AM
WTD: Beyma TPL 150H waterl00 Swap Meet 0 12th November 2011 09:50 AM
-Beyma TPL 150 AMT flshzug Planars & Exotics 1 23rd June 2008 11:45 PM
