While I understand that, I don't know enough about enclosure design to feel comfortable placing the port myself in a build like this. Just trying to figure out if Paul specified a location for the rear port on the Classix ii, or if there's a preferred place for some reason or another.
It really doesn't matter too much. Just avoid a placement close to a corner, because that would require a different tube length. Usual port location in small 2-way speakers like this is horizontally centered at tweeter height. Actually there are not many other options. Opposite to the woofer is often not possible because the opening of the tube gets too close to the driver's magnet and the space below is taken by the speaker terminal.
