How exactly does ARTA apply mic calibration file to measurements ? - diyAudio
Old 17th November 2014, 05:14 PM   #1
percy is offline percy  United States
Default How exactly does ARTA apply mic calibration file to measurements ?
If I plot my emm-6’s calibration file on a chart this is how it looks like.
You see those wild swings in the high range and some from –ve to +ve. I would like to understand how does ARTA apply such a calibration file to smoothed (1/3, 1/6,.. octave) as well as unsmoothed measurements ? Does it apply the calibration to the raw measurement or the final displayed measurement ? How does it handle measured points that happen to fall between the calibration file points ? Below is a snippet of the file. So what compensation would it apply to a point that is between -
9888.89 -0.6
10160.44 0.2
Or between –
14846.3 1.1
15253.97 0.6
Calib file sections -
9117.03 1
9367.38 0.3
9624.61 -0.7
9888.89 -0.6
10160.44 0.2
10439.44 0.4
10726.1 0.4
11020.63 1
12965.66 2.2
13321.69 1.8
13687.5 1.6
14063.35 1.6
14449.52 1.6
14846.3 1.1
15253.97 0.6
15672.84 0.9
16103.21 0.6
16545.39 0.7
16999.72 1.4
17466.52 0.8
17946.14 1.7
18438.94 1.7
18945.26 1.7
19465.49 2.3
20000 2.4
Old 17th November 2014, 06:04 PM   #2
You can view the graph of the interpolated compensation right in FR compensation dialog. That is covered in the manual.
P.S. I just noticed you can't resize the window for some reason, but you can click the copy button to copy a large size to the clipboard.
Old 17th November 2014, 08:36 PM   #3
JMB is offline JMB  United States
Hi Percy, though the best answer would be from the author, looking at my calibration and results, the calibration file appears to be interpolated to the measurement.
Old 17th November 2014, 11:34 PM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
Percy, your ECM-8000 is really quite flat - almost doesn't need a cal file. Certainly has way better bass response than mine.
That emm-6 cal file looks suspicious. There is way too much going on there for such a simple device. Maybe compare it to your behringer mic measuring a tweeter?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Old 18th November 2014, 12:52 AM   #5
Did you read the scale? I have an emm-6 cal file, here it is compared with that plot. Frequency scale is probably slightly off - I couldn't really tell which lines the labels went with - but it's close.
Old 18th November 2014, 01:09 AM   #6
@dumptruck:
The fr comp graph in arta is partly to blame for the confusion. It basically just added points between those wild peaks and dips. There is practically no difference in the shape of the curve.
I also downloaded another random calib file from dayton's website and it had the same characterisitics. Not sure if dayton's calibration method or file is flawed but I just expected to see a smooth rising or falling curve and not those crazy swings all over.
@Ron:
I remember having done some comparision measurements with the ecm8000 and while it escapes my memory what was the exact outcome I dont remember my ecm8000 to be flat above 8khz though. I somehow remember it as having lower response above 8khz than then emm-6. I will do that test again with and without compensation.
Old 18th November 2014, 02:20 AM   #7
Ron E's Avatar
Your mic did seem to roll off above ~10k - otherwise quite flat
Old 18th November 2014, 02:37 AM   #8
Originally Posted by percy View Post
@dumptruck:
Interpolation is normal processing proc., and yeah, they look comparable.
I don't think there isn't anything that crazy about it for the highest frequencies... AFAIK, Dayton still hasn't told anybody what their calibration procedure is, so nobody can really judge unless they want to pay for a certified calibration (which would be crazy). The cross spectrum guy posted some comparisons to his measurements years ago, which I just managed to drag up in google: http://www.htguide.com/forum/showthr...l=1#post472257
I never figured the Dayton calibration to be accurate down to these sub-decibel scales, but anyway I just looked through some old nearfield measurements done with that mic (figuring there should be some nice smooth pistonic driver behavior), and the little ripple ~200-500Hz in my cal. file does show up in the measurements. :shrug:
Arta Setup / Calibration Help skidave Software Tools 3 7th February 2012 08:24 PM
newb ARTA calibration ? Kepler Multi-Way 3 4th May 2011 11:21 PM
How can I apply a 24db/oct LR high and low pass filter to a WAV file? MikeHunt79 PC Based 12 21st May 2010 07:55 AM
Clio Calibration file - Similaritys? Benna Software Tools 0 27th December 2009 10:01 AM
ARTA calibration help augerpro Multi-Way 5 14th June 2009 11:11 PM
Copyright ©1999-2017 diyAudio
