Transmission line folds question - diyAudio
Old 9th November 2014, 10:01 PM   #1
Default Transmission line folds question
Just wondering if there are any rules regarding number/position of folds in a transmission line speaker? Does it matter how many folds there are as as long as the length/cross section of the line is correct?
Old 10th November 2014, 12:06 AM   #2
pkitt is offline pkitt  United States
This isn't a "rule" but the dividers that create the folds need to form line segments having a reasonably long length relative to the distance being traversed. For instance, let's say you wanted a total line length of 60 inches and the depth of the line is 6" along its whole length. If the line is folded once within a 30-inch height, each of the two segments would be 30 inches long, with the divider at 24 inches in length equaling 80% of the 30-inch run. Folding the line into 3 equal length segments creates 20-inch long segments with dividers 14 inches long, or 70% of their 20-inch runs. Folding the line into 4 equal segments makes them each 15 inches long with dividers 9 inches long, or 60% of their 15-inch runs. At some point, depending on all of the dimensions involved and the number of folds, you can end up with the dividers acting more like just solid braces than as line-forming members. My rule of thumb, then, which I cannot scientifically support from rigorous testing results, is to not allow the line dividers' lengths be less than 2/3 of the line segments' lengths, but shoot for 75% or more if possible.
Paul
Transmission Line Question jamiematrix Multi-Way 51 9th March 2013 11:34 AM
Transmission Line Question (Yet Another) schmeet Subwoofers 24 6th August 2008 10:18 PM
yet another transmission line question CharlieM Multi-Way 3 6th July 2008 05:44 PM
another transmission line question CharlieM Multi-Way 8 21st March 2008 11:17 PM
Transmission line question(s) Kris0603 Multi-Way 20 28th September 2005 11:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
