After searching many plans, I will build the Metaphor from Dillon Acoustics. Before I start I wanted to ask if anyone has heard these, and what they think. I do not design crossovers, so I hope his is as good as he says.
The only thing I plan to change is mine will have a closed box, no port. I will be using a sub-woofer. Has anyone built or heard these? tomcat9 |
#2 |
Sounds an excellent plan. The OW1 is another speaker using
the Hiquophon tweeter with a GR research bass/mid. On Dennis Murphy's site you can also find details of substituting other tweeters. Personally for a good value speaker I can't see the logic in spending more on the tweeter than the bass/mid unit. |
#3 |
Dillon has a very good reputation. Search the forum in
www.madisound.com You will find several messages. For a little more money, you should consider the Dillon Egos... in a sealed box, they are very small, would be very attractive for a HT/music system. You can find kits in www.zalytron.com. In any case, you should be very happy with Dillon's speakers. Al |
#4 |
Thanks for the 2 replies guys. I am starting to buy my parts. I may not be able to find a 65 uF cap for the crossover. Would a 64 uF be ok, or does it need to be exact? This 65 uF cap is in parallel with the tweeter. Also, I may need to combine two caps to make 65uF. To do this, do I connect the caps in parallel to add their values?
#5 |
Look here:
http://www.madisound.com/benniccaps.html You migh as Dillon or post in the Madisound Forum. Al |
#6 |
tomcat9
I hope you'll start a page in the wiki and log updates as you go along. I also did a lot of looking for just the right speaker and am still trying to decide between the Dillon ego, the Eros MkII from Wayne J. at speakerbuilder.com or the Hatt MkIII from Tony Gee's humblehomemadehifi.com. good luck |
#7 |
bradley,
I will need to see what the wiki is. I am new here. Also, I tried to look at the humblehomemadehifi page, but it could not be found. Al Garay, I looked at the benniccaps. I think the 65uF they have is not a polypropylene. I am trying to get all polpropylene or better for the best sound quality, especially for the tweeter. Thanks for the suggestion though. I found this on partsexpress.com "To add capacitor values, they can be connected to each other in parallel." |
#8 | |
64uf will be absolutely fine instead of 65uF. A 64uF capacitor with 5% tolerance is much better than 65uF with 10%. If they are both 10% then describing one as 64 and the other as 65 is pointless. You could always bypass the the 64uF with a very high quality 1uF capacitor, the result will be better than any 65uF capacitor you could sensibly afford. http://home.hetnet.nl/~geenius/ |
#9 |
sreten,
You are so right about the tolerances. I overlooked them. I have ordered some Dayton caps that are 10%, and some Solen that are 5%. I may try to use more Solen. I tought about the bypass cap also. I may try that. Thanks for the info, tomcat9 javascript:smilie(' ')cool |
#10 |
I have sealed LCR Metaphors in my HT/music system. They mate up with a sealed 3 cu ft shiva and MurphyBlaster SPCA's in the rear. Geoff did a wonderful job with the Metaphor. The Metaphor sound is a bit more laid back that the more detailed Ego (also a first rate speaker). However, for HT, the Ego's stain at higher HT volumes.
The OWI is fine with Geoff implementation of the 4th to 6th order acoustic 2100 Hz crossover point. I know others prefer the to cross it higher, but the Metaphor's and the Ego's just work well. I think the Peerless HDS benefits from the lower crossover. Ego vs. Metaphor Ego more detailed precise midrange smaller less SPL requires sub reveals poor recordings with ease Methphor All day listening sound midrange more laid back lower Hz extension higher SPL capability without distortion Bottom line Metaphor for larger HT/music mixed use Ego for music/small room HT Both benefit from a sub Good Luck, Jim p.s.- contact Steve at http://www.apexjr.com for larger caps |
| Raw Acoustics HT3 | audioferret | Multi-Way | 15 | 12th March 2006 12:48 AM |
| Dillon Metaphor/Box? | peterpan | Multi-Way | 1 | 3rd May 2004 10:16 PM |
| Need help in Acoustics! | audioPT | Multi-Way | 13 | 1st December 2003 10:13 PM |
| Dillon Acoustics EGO | harvardian | Swap Meet | 1 | 14th October 2003 01:56 PM |
| Page generated in 0.11195 seconds (79.53% PHP - 20.47% MySQL) with 11 queries |
