Tannoy Dual Concentric graphs
Old 7th November 2014, 06:32 PM   #1
beige is offline beige  Slovenia
Default Tannoy Dual Concentric graphs
Greetings!
I would be very thankful if someone would take a closer look at these graphs and explain the difference.
They both look pretty flat to me but there is quite a price difference so there must be some kind of catch. No free lunches!
Thank y'all.
Old 7th November 2014, 06:36 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Moved to Multi-Way.
planet10 needs your help:
Let's help Ruth and Dave
Old 7th November 2014, 09:03 PM   #3
dumptruck is offline dumptruck  United States
- the Di6 has an off-axis bloom at 2kHz that might be a bit annoying.
- the DVS8 has higher sensitivity and probably quite a bit higher max. output
- the DVS8 has a crossover null off-axis and the Di6 does not. I do not know why, maybe someone else is more familiar with these drivers and can explain.
Old 8th November 2014, 03:29 AM   #4
Bare is offline Bare  Canada
Seriously??
Those are 'Toy' mass market Tannoys.
Intended to keep the wolves from the Tannoy Factory door.. No More No less.
As you said; there ain't no free lunches.. Buy Cheap junk .. buy repeatedly.
Old 8th November 2014, 05:33 PM   #5
Pallas is offline Pallas  Pakistan
The DVS8, per Tannoy's website, is not a Dual Concentric but just a coaxial. Probably with a post-mounted tweeter like their cheaper ceiling speakers. Like a cheap car speaker.
The DI6DC is a real Dual Concentric, with the tweeter mounted behind the woofer and firing through their "Tulip" phase plug.
I expect that the DVS8 is the cheaper of the two, despite having a larger woofer.
I have no experience with the DI6. I have a set of the smaller Di5DC's installed for my upstairs balcony, and they're fine as extension speakers. They do have a midband resonance that's audible in critical listening.
Serious Audio Blog
Old 10th November 2014, 06:48 AM   #6
Thanks for the replies.
Yes, they have a plastic cabinets and look cheap but not many speakers comes with the detailed specs like these. You can get a fancier model of Tannoys with similar DC drivers and nice fancy cabinets for twice as much.
But than again - the DI6DC aren't exactly "free". For $350 each.
A coaxial speaker ought to be good in small rooms for surround purposes because the drivers are in phase at the speaker itself.
Tannoy Dual Concentric graphsHide this!Advertise here!
Tannoy SandringhamClone -- 8" Dual Concentric MLTL gripracer Multi-Way 14 19th June 2015 10:34 AM
FS: Tannoy 15 Dual Concentric Zedguy Swap Meet 3 12th September 2014 12:55 PM
WTB: Tannoy 2046 (Dual Concentric Driver) gk7 Swap Meet 4 3rd March 2014 02:39 PM
Tannoy HPD Dual Concentric 15inch JRKO Swap Meet 6 22nd December 2007 03:18 PM
Tannoy Dual Concentric Driver Unit PTSOUNDLAB Multi-Way 4 13th March 2004 09:31 PM
