#11 |
You need to consider the size of the airflow out of the port and
the way the wall interacts with the airflow. I'd suggest that a spacing of near 1/2 port diameter is the minimum spacing giving the most detuning, and once you get to port diameter spacing further spacing is not critical for port tuning, but larger spacings are critical for upper bass/mid balance. Nearer wall spacing less than 1/2 port diameter by minor adjustment is more flexible than "port bunging" with foam. |
#12 |
SY, Sreten:
Figured it would be something like that. That is, just a few inches. The reason I figured the space would be small is that essentially this situation would be a downfiring port, only using the wall instead of the floor. I have come to understand that this downfiring port configuration has many advantages, and the ones I have seen are never more than an inch or two off the floor. So I guess once you go more than few inches away from the wall, you are in a situation it doesn't matter much where the port is. But if you move it up closer, you might get some advantages.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
| Rear port and front port | barry.childs | Multi-Way | 10 | 27th February 2009 09:46 AM |
| Front or rear port placement? | JLC7 | Multi-Way | 14 | 26th May 2008 08:04 PM |
| Rear or front port? | Speek | Multi-Way | 1 | 7th September 2005 08:58 AM |
| front or rear port | blu_line | Multi-Way | 3 | 12th March 2004 01:20 PM |
| rear port vs front port | Jimmy154 | Multi-Way | 22 | 6th March 2004 08:38 AM |
| Page generated in 0.07254 seconds (69.80% PHP - 30.20% MySQL) with 10 queries |
