Interesting old speaker w/dual L-pads - diyAudio
Old 16th October 2014, 08:30 PM   #1
Default Interesting old speaker w/dual L-pads
While I was cleaning out the house I grew up in recently I had a look at our old stereo system. One interesting thing I found was the Synergistics speakers, a brand no one has ever heard of. My Father bought these in the mid-70's and they were probably a mid-quality range item at the time. The drivers were all flush mounted, the midrange is housed in a closed chamber made of a heavy cardboard tube, and the acoustic suspension cabinet is well stuffed with fiberglass. These speakers have some interesting features I have not seen before. I am curious if any of you have come across anything like these before.
The drivers are all paper cones. The midrange unit has a dual cone and is of Belgian manufacture. I don't know what Belgian company was in the speaker business at that time. The tweeter is a typical 2" paper cone. The woofer does not have markings indicating origin, and it does not have a ferrite magnet like the mid and tweeter have. It looks like it may be an Alnico magnet inside a steel "cage". Finally, the crossovers for both the midrange and tweeter have adjustment pots on the rear plate. This looks like two L-pads. I'm guessing they must have been thinking you could compensate for room size or near wall placement with this adjustment system. I have never seen dual L-pads used.
See the the attached pictures.
The woofers have thick and sturdy paper cones with a lot of raw pulp texture on the back, and the dust caps are linen. You can see the end of the steel pole piece through the caps. The bass is probably the best feature of these speakers - very strong and decently deep, probably 40 Hz. If those woofers were run with a cross-over instead of full range I bet they could sound quite good. I might save them for a project, maybe garage speakers or something.
Old 16th October 2014, 09:27 PM   #2
system7 is offline system7  United Kingdom
system7's Avatar
Fascinating old clunker there. I like it! Nice photo essay too.
I suppose it's made in the USA, but the mid is a Dutch Philips AD 5061 M8 on 6uF HP filter. Google it. Almost a full ranger. Can be ferrite or AlNiCo magnet.
The bass looks quite decent too. Rubber roll surround that might come up nicely with some silicone grease. Those linen dustcaps work well, IMO. Like no dustcap at all acoustically.
Cone tweeter on 3uF HP filter. Nothing wrong with that. Could even be that classic Peerless mylar cone used by Mc.Intosh a lot.
Many speakers of this era used series crossovers. Yours is quite simplistic, but you could do a lot with it to improve it IMO. I think you could get it sounding very good.
Simple parallel crossovers discussed here: SEAS Kit 503
Below is a 4 ohm Tandberg HiFi 15 design from this era, which used a series filter on a similar driver compliment. A lost art, IMO. Old speakers always interesting. Thankyou for sharing.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK.
Old 16th October 2014, 09:35 PM   #3
mondogenerator's Avatar
But the mid has "made in Belgium" printed on the back
Otherwise faultless.
Looks like simple parallel 1st order for both mid and tweeter. Unless there are some coils I'm not seeing.
Every new piece of knowledge pushes something else out of my brain - Homer.....................Simpson
Old 16th October 2014, 09:59 PM   #4
kevinkr's Avatar
The name sounds vaguely familiar, might have been someone's house brand. I've certainly seen far worse in that time frame..
A lot of 3 way speaker systems of that era had L pads for the mids and highs, indeed my diy Onken based system does too. (I keep meaning to replace them with fixed resistors, but in 7yrs since I designed these XO never have)
Technically in your speakers they are rheostats since there are only two wires connected, so not really L pads.. The cross over frequency probably varies pretty significantly depending on how the pots are set. These might really benefit from a decent XO, but you'd have to do some basic measurements first.
The caps look more typical of 1960s vintage bipolar electrolytics, but were perhaps left overs in the manufacturer's inventory or perhaps they made that style for longer than I realized.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 16th October 2014, 11:16 PM   #5
The woofer looks a lot like the CTS 12" we used to use at Infinity, back in the early '70s. Cost us about $12 each, and worked pretty well, if you didn't abuse it. Cone breakup is around 1200 Hz.
Old 16th October 2014, 11:44 PM   #6
Ah, of course, Philips! It makes sense they would have some manufacturing facilities in neighboring countries. Do I detect a note of international rivalry there monodegenerator? ;-)
I think it is right that the pots wired as they appear to be would be affecting the X/O points. I did not see any coils hidden in there behind the fiber bats so this must be a woofer running full range, a mid high-passed on the low end and also left full range on the top end, and a tweeter high passed on the low end. All 1st order. Ginning up a series crossover for it would be a fun exercise. Don't know if I can find the time for it.
Thanks for the insights, all!
Old 17th October 2014, 03:17 AM   #7
Moondog55's Avatar
Looking at the front baffle I think the mid and tweeter may have been replaced at some stage
Is that perhaps a Phillips mid? Looks sort of familiar
If the tweeter has been changed the original may have been a paper coned oval
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 17th October 2014, 03:35 AM   #8
frugal-phile(tm)
planet10's Avatar
On 1st siting,i'd guess the tweeter is the very nice Peerless unit.
Any numbers at all on the woofers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th October 2014, 01:42 PM   #9
kevinkr's Avatar
I've definitely seen and heard these somewhere, just not sure when and where..
I believe those are the original drivers, not changed out.
They manufacture(d) many things in Belgium, including automobiles interestingly enough. (Adzam aka Belgian Mazda made good vacuum tubes.)
Old 17th October 2014, 02:30 PM   #10
Speakerholic
Cal Weldon's Avatar
I bet a coil on the woofer, a coil and larger cap on the mid and wiring the L-Pads properly would go along ways to making these sound Jim Dandy.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Interesting new active speaker from Emotiva.. Remlab Multi-Way 3 4th June 2013 12:04 AM
Interesting fullrange speaker from China talaerts Full Range 25 6th May 2012 03:02 PM
Interesting midrange horn speaker kipman725 Multi-Way 2 7th April 2011 04:11 AM
Interesting Site on Speaker Design davecandialex Multi-Way 8 29th December 2010 03:11 PM
Interesting OB speaker project ion Multi-Way 4 11th March 2008 12:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
