Active crossovers from eBay? - diyAudio
Old 15th October 2014, 01:57 PM   #1
lorienblack's Avatar
Default Active crossovers from eBay?
Anyone had experience with these active crossovers? To the untrained eye they look similar to some of the builds on this forum.
High Performance Line-level Active 2-way Crossover Filter OPA2134 DIY KIT | eBay
Any thoughts appreciated - thanks
SQ exists only in your head :P
Old 15th October 2014, 02:57 PM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Would be nice if they provided a little more information - like is this an LR4 two-way for instance? Also 'High Performance' seems a bit rich when this is just a standard opamp inplementation with no attention to power supply cleanliness.
Later... I looked at the link to the PCB - too much hype for my taste, for example 'performance a vast improvement over nearly all passive crossovers'. They're using too many opamps to implement a 12dB/8ve XO, this can be done with one dual opamp (since ite PCB is mono).
Seek not the favour of the multitude...rather the testimony of few. And number not voices, but weigh them. - Kant
The capacity for impartial observation is commonly called 'cynicism' by those who lack it.
Old 15th October 2014, 02:58 PM   #3
Not tried this product myself, but it looks good overall. Easier than perfboarding from scratch! I will bookmark it for myself, thanks...
His store lists both "12dB crossovers" and "Linkwitz-riley crossover" categories separately. Make sure you know which one you want. I would prefer LR12 for flat sum.
I'd rather use LM833 than his proposed 5532 or 2134, but I'd prefer Signetics 5532 over any 2134, but beware counterfeits.
Old 15th October 2014, 03:17 PM   #4
Mooly's Avatar
lorien... I have merged your two threads.
Installing and using LTspice. From beginner to advanced.
Old 15th October 2014, 08:39 PM   #5
Bare is offline Bare  Canada
Not seeing any trims or pots to adjust levels and crossover points.
A fairly basic requirement IMO.
Old 15th October 2014, 09:02 PM   #6
It's not sold as an adjustable feast, you determine co by resistor selection.
Maybe "maybe" a stepped potentiometer system could be fudged, but I'm only using this for my vinyl. I will have determined my ideal co with some mini dsp kit and a couple of amps.
Power for active crossovers in Active monitors argonrepublic Power Supplies 1 22nd February 2013 05:23 AM
Active crossovers GRollins Solid State 42 26th August 2006 10:26 AM
active crossovers, please help herbd2 Multi-Way 2 23rd February 2005 04:21 PM
Active Crossovers. hacknet Solid State 3 18th February 2004 12:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
