Two Questions - ESP Audio proyect, Loudspeaker Protection and Muting - diyAudio
Old 14th October 2014, 02:07 AM   #1
Fedess is offline Fedess  Argentina
Default Two Questions - ESP Audio proyect, Loudspeaker Protection and Muting
Hi everyone,
I'm going to build Rod Elliot's circuit for Loudspeaker DC protection and muting.
This is the link:
http://sound.westhost.com/project33..../project33.htm
I have two questiions about it:
1) I'm going to apply this circuit to protect four channel (a bi-amped stereo system), as the circuit is shown for 2ch operation, my question is how do I add the "DC detector". Should I build two of the "figure 1" detector (please refer to link), or can I do the modification as shown in PS2.JPG? (attached file)
2) Rod Eliiot wrote:
NOTE: The power supplies (+ve and -ve) shown in these diagrams will normally be the power amp supply rails. Do not try to substitute different supplies unless you know exactly what you are doing, or the circuit may not work properly. This is especially true of the muting circuit, but incorrect supplies will (may) also affect the DC detection circuit. Like most of my projects, this is intended for experienced constructors.
In my system each channel has it's own rail, and I have only one transformer. Please see PS.JPG (attached); do you think I should have any consideration about this? I don't find any problem with this, but I just want to be sure before building and connecting anything
Old 14th October 2014, 02:27 AM   #2
bimo is offline bimo  Indonesia
bimo's Avatar
Originally Posted by Fedess View Post
Hi everyone,
This is the link:
You can use it if you have same ground of your all amplifier and the dc protector.
Old 14th October 2014, 03:32 AM   #3
Yes, I do have same ground of all the amps, thanks.
What about question 1?
Muting arrangements for ESP kits: P05B and P09B Zoodle Analog Line Level 1 10th October 2012 12:42 AM
ESP Project 104 muting problem kjb Analog Line Level 4 4th September 2011 06:27 PM
Velleman K4700/ K4701 - Loudspeaker Protection Kit for car audio Sweetrobot Parts 5 16th September 2009 07:37 PM
ESP Project 19 with LM3876 Keeps Muting Itself jackand08 Chip Amps 4 2nd January 2009 11:58 PM
loudspeaker protection and muting circuit trouble :( Mattyo5 Solid State 1 21st March 2004 02:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
