Jeff Bagby's XLS Software ? - diyAudio
Old 8th October 2014, 04:17 PM   #1
Zero D is offline Zero D  United Kingdom
Default Jeff Bagby's XLS Software ?
I'm using the free Spread32 XLS which works fine on other .XLS's but with JB's Woofer Box and Circuit Designer 5.xls it says it's PW protected. Is this correct, & if so what's the PW ?
TIA
Old 8th October 2014, 04:23 PM   #2
Jeff doesn't share the password to any of his spreadsheets and this should not be necessary for you to use it. The password gives the user access to all his VBA code, which is Jeff's personal property.
His spreadsheets only work in Excel, and with 32 bit O/S versions. Many of his programs no longer work properly for me under Excel on a computer running Windows 8.1-64bit.
You are probably SOL with Spread32.
"Hardware eventually fails. Software eventually works" - Michael Hartung
Old 10th October 2014, 02:06 AM   #3
@ CharlieLaub
Thanx for replying.
Bill poster had the same issue also with another of JB's software FREE Passive Crossover Design 7 software released
I'm on XP
Why it asks for a PW just to run the spreadsheet though ?
Old 10th October 2014, 04:21 AM   #4
You're missing the point. The macros won't run on anything but Excel. On Excel it doesn't ask for a password.
I was so much older then, I'm younger than that now.
Old 10th October 2014, 08:06 AM   #5
Scottmoose's Avatar
Designed for Excel, works perfectly in Excel, whether you're running 32 or 64 bit Windows 7 (I have systems with both) or XP. I can't speak for Windows 8 -I avoid it like the plague.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 11th October 2014, 06:38 PM   #6
@ fastbike1 & Scottmoose
Bill poster also had the same PW problem even though he is using MS Excel FREE Passive Crossover Design 7 software released
"Maybe" he hadn't updated Excel to the specs required, as mentioned on the download www ?
F/S: Morel & SB Acoustics kit designed by Jeff Bagby osd1 Swap Meet 2 20th May 2014 03:44 AM
Jeff Bagby Kairos near-wall dynaco9002 Multi-Way 9 5th February 2014 12:12 AM
Jeff Bagby Continuum vs Fusion-12 Tempest SEOS nrg2009 Multi-Way 16 1st February 2014 02:44 AM
FRD and other Jeff Bagby spreadsheets jamikl Multi-Way 15 19th June 2013 10:41 AM
"The CSS 'Next Generation' High Resolution 'Triton' Kit" designed by Jeff Bagby woodsart Multi-Way 88 29th December 2012 12:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
