Help with open baffle and woofer box design please - diyAudio
Old 21st September 2014, 01:29 PM   #1
Default Help with open baffle and woofer box design please
I plan on doing an open baffle with a Fostex FE206En full range driver and a Kef B200 woofer in a woofer box below the open baffle. I need some help with the design and plans for the box and the baffle please. I intend on using 18mm MDF for the build.
Here are the specs of the drivers.
Old 22nd September 2014, 12:56 AM   #2
The spec sheets appear to be using different methods for determining sensitivity, maybe someone who's good with dB math can tell if they're equivalent.
First thing to do is decide how wide a baffle you can live with...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 22nd September 2014, 01:08 AM   #3
Simply a very poor combination, unless active
biamped, and flea power for the top end.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 22nd September 2014, 08:30 AM   #4
jerome69's Avatar
Hi, This combination could work well
The B200 in a "closed" box and the FE206 on a panel.
A closed box (50L). But I recommend an aperiodic BOX with a variovent . You can make a TL line too
You should have 84dB of sensitivity with the crossover.
The F206 on a panel 25cm large (The woofer box has the same width). This gives you a corner frequency near 688Hz.
The crossover is simple, crossover frequency near 500Hz. This could be a starting point
L on the woofer 4.7mH . Could be a 12dB with 47uF in parallel, you can try.
R and C on the FE206 (22 ohms / 10uF )
Hope this helps.
Old 22nd September 2014, 09:30 PM   #5
Hope this helps.
I will be bi-amping the set, with a tube amp for the Fostex and a hybrid for the woofer.
Any other cheap drivers to be recommended in stead of the B200?
Old 23rd September 2014, 10:35 AM   #6
jerome69's Avatar
Cool if you go to biamp
You can go to line level active or line level filtering
Euh go to the 8" you want
HiVi B3N Open Baffle w/ Woofer FAST Design NcHalfrican Multi-Way 3 14th April 2012 05:22 PM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer? Spasticteapot Multi-Way 2 27th November 2006 09:49 PM
DIY Open baffle / Sealed woofer design preiter Multi-Way 11 25th August 2006 05:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
