Notch Filter Calculator - diyAudio
Old Yesterday, 10:19 AM   #1
raelman is offline raelman  Spain
Default Notch Filter and Crossover Calculator
Hello everybody:
I'm plannig a new building: Vifa XT25 + Fountek Fw146 + Fountek Fw200
I have calculated a theoretical crossover from the FRD/ZMA cueves traced with SPL Trace from the manufacture's data. Attached you can find the Xover.
What I can't calculate not simulate is the appropiate Notch filter needed to smooth the resonance on the Fw146 at 5kHz.
Could anybody help me or calculate the appropiate notch filter?
I think the filter should correct from 5 to 20 kHz about 12db/octave
Thank you in advance to everybody!
Old Yesterday, 11:28 AM   #2
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Not a great idea to attenuate the response of the bass driver.
Better use more sensitive midrange and pad it later. You are
making yourself job more difficult working with aluminum.
Try increasing the C and L value for the mid LP filter and see
how it looks. If that does not help, add another inductor for a
3rd order. After these modifications you will know better how
to proceed.
It is so good that you exist !
Old Yesterday, 12:40 PM   #3
I suggest the OP download Xsim software (free) and try his design once again as a sanity check. Harris Tech., while nice, is not my favorite any more since the recent release of Xsim by Bill Waslo. There is a thread in this forum from BW that introduces the software.
"It's all about the music!"
Old Yesterday, 03:23 PM   #4
Well, trhe problem, as a newbie, is that I have bought all the stuff and built the cabinets... so I have to work with those drivers and find the way to make them work.
If somebody wants to help me, I can sshare the X-Over 3 filer, Xsim file, FRD and ZMA files....
Thank you again.
Old Yesterday, 03:31 PM   #5
Inductor's Avatar
It would be nice posting the FRD and ZMA files as .txt @diyAudio.
You need to change the termination (only the termination name as txt file to post here) to do that.
Old Yesterday, 03:34 PM   #6
Inductor's Avatar
At the same time post the size and volume of the speaker you envisioned, like the front baffle dimensions and depth, internal volume in liters and type of alignment (frequency for a BR)
Old Yesterday, 03:53 PM   #7
The cabinets volumes where calculated with Bassbox6.
Fountek FW200 needs about 23l CLOSED box.
Bass section is 700h x 170w x 200d all milimeters what means 23,8 liters.
Will be very very heavy damped.
I attach the FRD and ZMA files from all the drivers and the front baffle.
Sizes in milimeters.
the Zip files are RAR files in fact, but I had to rename it to be able to be uploaded.
All the stuff is at home unless Xover components since I'm getting crazy to design it.
Thank you everybody for your help.
Old Yesterday, 06:09 PM   #8
Eldam is offline Eldam  France
Why not change the Fountek Fw146 by a Scan Speak model 10 ?
Old Yesterday, 07:07 PM   #9
Lojzek's Avatar
raelman,
with the same values I got different results than what you posted.
This is just for the sake of a principle in general and not a solution
per se. I simulated in PCD7 by Jeff Bagby with parts as shown in
the schematic.
Since you have drivers and box already built, make the measurements
and then use frd and zma for simulation.
Old Yesterday, 07:21 PM   #10
Your sim seems to be good. I have triespd the same sheet from Jeff baggy too, but in any case it can't smooth the mid resonance at 5khz.
Any idea?
Thanks for your simulation.
notch filter/shelving filter for Alpair5? mondogenerator Full Range 0 29th June 2011 06:13 PM
Notch Filter Design - Seas L21 (H0955) Breakup Modes:Single or Multiple Notch Filters dtm1962 Multi-Way 10 8th February 2010 02:17 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Need a notch filter calculator. GuyPanico Multi-Way 4 17th July 2006 02:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
