Physical time-alignment of drivers - diyAudio
Old 17th September 2014, 03:00 AM   #1
Brisso57's Avatar
Default Physical time-alignment of drivers
Hi All,
In cabinets where the mid and the tweet are located above the woofer and offset rearwards, by what method is the optimum offset calculated?
(Please don't tell me it can be done electronically. We all know that.)
Let's assume - for simplicity - that we have all cone drivers.
What point on a cone is taken to be the reference? The projected apex? The centre of the base? Something else?
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 17th September 2014, 03:02 AM   #2
Its better to measure this using the interference between the output from two drivers and fitting the offset. There is a good explanation of this technique written by Jeff Bagby called "How To Use Passive Crossover Designer To Find The Relative Acoustic Offset". Just google it.
"Hardware eventually fails. Software eventually works" - Michael Hartung
Old 17th September 2014, 04:56 AM   #3
Originally Posted by Brisso57 View Post
Hi All,
Good question, but we don't measure it with calipers and measuring tape.
We don't really even measure "absolute" offset.
As shown in the paper Charlie mentioned, what we measure is simply the phase response. by simulating different phase interactions between two drivers until it is identical to the measured simultaneous phase response, you get your z-offset from one driver to the next.
Old 17th September 2014, 05:29 AM   #4
MiiB is offline MiiB  Denmark
you have to measure the delay, The delay is a function of mass and the drivers acceleration-factor, I can't be judged from any geometry observations. most often speaker designers neglect this or doom it non important as they introduce a phase-shift over the crossover region anyway
Woofer + Tweeter: Physical time alignment ramiro77 Multi-Way 39 27th December 2013 06:59 PM
Time alignment jmar Multi-Way 7 1st January 2010 02:51 PM
time alignment? flaevor Multi-Way 7 18th August 2006 12:51 PM
Push Pull woofer physical alignment eRiCdWoNg Subwoofers 1 7th June 2005 09:46 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
