Need help identifying driver - diyAudio
Old 13th September 2014, 01:11 AM   #1
Default Need help identifying driver
Specifically the midrange, but if anybody knows of any good replacement drivers in case others fail it would be greatly appreciated. The midrange has failed in this case, so i do need to replace those.
Old 13th September 2014, 01:12 AM   #2
The midrange is sealed separately from the rest of the cabinet.
Help identifying compression driver failure RockLeeEV Multi-Way 6 26th August 2014 03:51 AM
Help identifying driver stage tubesmuggler Tubes / Valves 4 8th April 2011 02:27 PM
identifying old fostex driver bemoth Full Range 4 10th October 2007 04:43 PM
Help Identifying Nakamichi? Driver. Forster Multi-Way 0 29th November 2006 07:17 PM
Please help identifying this FRENCH driver exurbia Full Range 18 5th June 2006 11:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
