Old 16th January 2004, 03:16 AM   #1
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Question I'm Torn Between Which Design To Build
Hello Fellow Do It Yourselfers!
I have the option of making either two 8 inch reflex subs,
or two 12 inch sealed subs for my mom's video entertainment
center.
Minus 3db on the 8 inch reflex subs are 36.57 Hz, while the
12 inch sealed sub, is 41.97 Hertz. (Measurements scaled
using one enclosure)
The Xmax on the 12 is 7.62 mm, and the 8 is 8.45 mm
Although the 12's require a larger cabinet than the 8's,
that's not a problem.
So, which one would you choose?
They are going to get powered by a Soundcraftsmen 7502,
Bridged Mono (840 watts = 420 a speaker) So, power is
not an issue.
The issue is deciding between the two. Your opinions
will be the deciding factor.
Thank you.
OMNIFEX
Old 16th January 2004, 03:37 AM   #2
leadbelly's Avatar
2 12's all the way; they'll move a lot more air than the 8's.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 16th January 2004, 03:41 AM   #3
Send a message via AIM to ScottRHinson
What drivers are you looking at? If they are both quality drivers, with relatively low distortion, and "real" excursion specifications then go with the 2 12" woofers. The 2 12" woofers will have roughly twice the volume displacement of the 2 8" woofers, and will be able to play substantially louder. You might get more "punch" from two 8" woofers depending on the bass alignment you choose, but it won't be *real* deap bass.
Scott
Old 16th January 2004, 05:12 PM   #4
Ken L is offline Ken L  United States
Default Re: I'm Torn Between Which Design To Build
Go with the two 12's
a pair of 12's beats a pair of 8's in Poker and in Audio.
any time _big grin_
Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 16th January 2004, 05:20 PM   #5
leadbelly's Avatar
Default Re: Re: I'm Torn Between Which Design To Build
If your deck has 12's in it, I bet you win a lot at poker. Or is that how you pay for your system?
Old 16th January 2004, 06:00 PM   #6
frugal-phile(tm)
planet10's Avatar
based on the info you have provided i'd go with 2 12s, although personally i'd rather use 4-8s (or 4-10s or 4-12s )
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th January 2004, 06:59 PM   #7
Default Re: Re: Re: I'm Torn Between Which Design To Build
I never said I was playing with a full deck _ big grin_.
Or maybe "two bricks short of a load" ?
Or how bout " his elevator doesn't stop on all floors"
Or " one sandwich short of a picnic"
and last but not least, my personal favorite from "The Green Mile"
"this boy's cheese has done slipped off of his cracker"
_really big grin_
Ken L
Old 16th January 2004, 08:10 PM   #8
Bull is offline Bull  United Kingdom
Default reply
Well it depends how much floor space you got in your living room.
2x 12 inch might take up too much floor space in a medium room where 2x 8 inch would be fine in a small/medium room,or 2x 12 inch in a large room would sound better.
Old 17th January 2004, 12:29 AM   #9
OMNIFEX's Avatar
Thanks Everyone!
I was leaning toward the twelves myself.
Bull
This is for my mom's video system in her bedroom.
She likes to come home from work, laydown, and,
watch DVD's.
Floor Space isn't a problem.
Thanks.
OMNIFEX
Old 17th January 2004, 03:12 AM   #10
Bose(o) is offline Bose(o)  Canada
In addition to Ken,
"One Froot short of a loop."
good 'ol froot loops.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
How to patch a torn speaker? syntrax Multi-Way 3 1st December 2006 08:49 PM
Help with torn cone mdelrossi Multi-Way 12 18th October 2006 12:34 PM
Repair Torn Speaker? james___51 Multi-Way 11 10th August 2004 10:21 PM
Page generated in 0.10552 seconds (77.51% PHP - 22.49% MySQL) with 10 queries
