need advice for pc speakers
Old 15th January 2004, 08:39 PM   #1
Tincho is offline Tincho  Argentina
Question need advice for pc speakers
I have some 4" speakers and would like to build some PC speakers. I've performed T/S measurement giving aprox.:
Qms: 3.3 Fs:82
Qes: 1.5 Fb:120
Qts: 1 Vb:.12 ft3
Vas: .14 ft3
The problem is that the box calculated is huge for such as small speaker:
ISD results
sealed : 17 litres Qtc:1.12
vented : 75 litres T:32Hz Ql:7.00 Vent Match 0.04
Is there any possiblities to reduce size???
Thanks!
Tincho
Old 15th January 2004, 09:31 PM   #2
coolkhoa is offline coolkhoa  United States
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
The enclosure volume you specify for the sealed box already has a high Q of 1.12, so I wouldn't recommend going any smaller (sizewise) to avoid overly boomy bass. In fact, even 1.12 is too high a Q for me; I'd stick with a max of 0.8. But then again, if it suits your tastes, by all means go for it.
Other options you could try are the isobaric sealed box, which uses two identical drivers and cuts volume in half, and the aperiodic enclosure (think of it as a cross between the sealed and vented varieties).
Good luck.
KTK. Kool To the Kore.
need advice for pc speakersHide this!Advertise here!
Jordan 2 way speakers advice please! Bill poster Multi-Way 9 11th June 2008 03:17 AM
DIY speakers, need advice cruor Multi-Way 4 9th January 2005 12:13 PM
Need some advice looking for speakers Paulr Multi-Way 1 18th November 2003 04:49 PM
Diy speakers - advice miguel2 Multi-Way 1 10th November 2003 10:21 AM
Need advice on dj/pa speakers ogp Multi-Way 3 20th September 2001 12:40 AM
Copyright ©1999-2017 diyAudio
