crossover diy help - diyAudio
Old 28th August 2014, 12:44 AM   #1
2g60s is offline 2g60s  United States
Default crossover diy help
looking for advice on what software to use and what equipment I need to correctly build a 3 way crossover.
and maybe an answer to a possible dumb question
I'm currently using a 2way crossover converted to a 3way ie a a 2way feeding another 2way. the 2way for the mid and tweeter was designed for those speakers i added a crossover before that for lower frequencies.
so the question is should I scrap all of it and start fresh or just better design the crossover that i have feeding it?
I'm a n00b to crossovers any help would be good thanks
Ted
Old 28th August 2014, 03:50 AM   #2
Inductor's Avatar
It's only by chance that your speaker works. After saying that some crossovers have stages like that but they where calculated as such, I think the Dahlquist DQ-10 is one of them.
https://bspace.berkeley.edu/access/c...-crossover.jpg
Old 28th August 2014, 01:48 PM   #3
Inductor's Avatar
Originally Posted by 2g60s View Post
looking for advice on what software to use...
I use quite a lot FRD/ZMA's.
I never used SW but maybe what you are looking for.
Old 28th August 2014, 02:20 PM   #4
Default Try Jeff Bagby's design tools
Jeff Bagby's Software Page
Old 29th August 2014, 12:38 AM   #5
oldmanaudio's Avatar
Introduction to designing crossovers without measurement. You can find it here on diyAudio
Diy digital crossover hugostensson Digital Line Level 28 7th November 2011 11:50 AM
DIY crossover inductors Alex M Multi-Way 4 27th August 2010 04:17 PM
DIY Active crossover !!!! zztop Solid State 19 27th February 2008 06:48 AM
DIY Active Crossover darkm4n Car Audio 6 12th August 2005 08:16 PM
diy crossover? TheCrazzyman Multi-Way 1 19th January 2004 08:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
