Looking to buy a Dynaudio esotar 330d - diyAudio
Old 27th August 2014, 08:07 PM   #1
Default Looking to buy a Dynaudio esotar 330d
I am looking for one or a pair of the Dynaudio Esotar 330d. Currently one side of it stops working, I measured the resistance, it is around 32Ohm instead of 5.2Ohm. I do not see anything obvious when I took it apart. Everything seems to be intact, no burning of wires on the diaphragm.
Anyone who has repaired this type of tweeter before? Help!
Old 28th August 2014, 10:23 AM   #2
As long as you send in the dead driver Dynaudio will replace it (at your cost obviously) as far as I know.
Old 28th August 2014, 03:23 PM   #3
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Aklzy,
first have your suspicious driver's impedance and FR measured.
Then we will know more. Yes, factory would gladly take a faulty
driver, replace it with a refurbished one and charge appropriately.
It is so good that you exist !
Old 28th August 2014, 06:50 PM   #4
Thanks for the suggestion, What is a FR?
At first the sound was fading in and out, when more power it put in, it was fine for awhile, then back fading in and out again. At the time the resistance was fluctuating, after I took it apart to clean everything and put back. The resistance stayed at 32 Ohms, tweeter stops fading in and out, it is just really quiet.
Old 28th August 2014, 07:25 PM   #5
Lojzek's Avatar
FR is frequency response. So, are you saying your
driver was working ok and then something happened
and now dcr measures 32 ohms?
How are these Esotars implemented in a speaker?
You said that you performed a cleaning. You have
probably removed the ferrofluid. Did you clean the
magnetic gap too?
Dynaudio Esotar T 330D pumo Swap Meet 6 8th December 2011 12:50 PM
Wtb: [pair] dynaudio esotar 330d elecres Swap Meet 1 25th August 2010 02:55 AM
Dynaudio Esotar T-330D tweeters... Brand NEW HarryKimura Swap Meet 10 30th October 2009 04:04 AM
Dynaudio Esotar T-330D for sale chengtaw Swap Meet 1 3rd January 2009 10:41 PM
FS: Dynaudio ESOTAR T330D + ESOTAR M560D zino Swap Meet 2 17th May 2004 11:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
