I believe I want my first real DIY speaker project to be a center channel. This is the speaker I listen to most often, and it will offer the most learning experiences for me.
I have decided on a WMTW design, I have a fairly small amount of space to use, and a small budget as well. It will need to be shielded as well. T TB 28-8485A Tweeter, 2nd or 3rd order at 4KHz M TB W3-879S 3" 2nd or 3rd order bandpassed from 350Hz to 4Kz (is a bandpass advisable?) 2xW TB W5-876SA 5" 2nd order Low-Pass at 350Hz. This should run abuot 75 for the drivers, and I would like to stay under 15 or so for the crossover. From what I have been learning, the impedence and freq response curves should work nicely at these crossover ferquencies, though I will use WINISD to verify this. Thumbs up, or am I way off bass (pun intended) here? BTW I intend on replacing the mains to match this setup later on down the road, they are currently low rate Pioneers... |
#2 | |
But $15 for the crossover? You'll spend more that that on just the inductors.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Yes you are right. I was just looking through the PE pre made Xovers and they run 40 bucks. Still, that would total 115 for a very nice center channel.
Previously I had been looking at a 300 dollar Inifinity CC and I dont think it would sound nearly as nice. Plus I could later match these with a TW or TMW mains and TM surrounds... |
#4 |
I am also very new to speaker building...and I would also like to build a CC. I have recently learned that my original thought of copying the popular MTM is not the way to go. I also was thinking of the WMTW configuration...when I thought of using a couple coaxial speakers instead....like what is seen in car audio.
I know that a speaker company (I think B&W) has done a simillar thing.... Any thoughts on this???? |
#5 |
If this is you first DIY project .. be carefull .. be very carefull ...
www.spearkplans.com may help . Be carefull to join all the board's corectly , to cut them good ... i recomand that someone else to cut them ... Good luck !! Bye |
#6 |
This will be my first Xover design, but cutting isnt an issue. I have built boxes before and they came out very nice.
I think for the 3 way X over I will do like so: [edit I tried to ASCII art it, but forget it] First order Mid/Woof Xover C1 39.8uF //High pass 500Hz L1 1.82uH //Low pass 350Hz Second Order Mid/Tweet Xover C2 3.517UF //2nd order HP 4KHz L2 .45uH C3 4.193uF //2nd order LP 3.5KHz L3 .51uH Parts should run about 30 bucks Does this sound right? Looking at the impedence graphs, it *should* average out to 8ohms across the board. What is a good software program to use ro add the freq response and inpedence response graphs? By the way, I could save alot of money by replacing C1 with a cheap electrolytic cap. Would I notice the difference?? |
#7 | |
http://design3d.host.sk/Hi-Fi/Audax/ht_center.htm If you like coax, Tony Gee's USB looks good: http://home.hetnet.nl/~geenius/USB.html
#8 | |
#9 | |
... meaning the sensitivity of the tweet as opposed to the midrange? Well, I am still learning, so my guess (and I am asking for input here) that I would need a resister to pad the tweeter or an L-pad (and I have never used an L-pad). Whats the best way to determine resistance needed or what sort of L-pad I would need? Also, I am not sure how to handle the Woofers in this case. They are going to be run parallel at 4ohms, and I know larger speakers are less efficient, so I would assume this would make up for that (having two in parallel). Oh, but then I would underload my amp. Well, thats why I am here I guess. I plan on getting the LoudSpeaker CookBook before I begin of course. Or, I could just buy the prebuild Dayton Crossover. Would that be the better way? I really would prefer to do it myself... |
#10 |
Oh, you mean the frequecny response when you say sensitivity? To me it looks like it will flatten, but I will have to use software to be sure, right?
| My Hi-VI B3S Bipole Center Channel Project | owdi | Full Range | 14 | 28th April 2007 12:00 AM |
| Center Channel Project finished after nearly a year of work. | kingdaddy | Multi-Way | 8 | 29th November 2005 01:48 PM |
| MTM center channel project | Deagle50ae | Multi-Way | 23 | 15th March 2005 05:54 AM |
| New Center Channel Project | scooterdog | Multi-Way | 0 | 30th March 2003 07:44 PM |
| Center Channel project | ssurban | Multi-Way | 2 | 8th January 2003 02:19 AM |
| Page generated in 0.10008 seconds (88.56% PHP - 11.44% MySQL) with 10 queries |
