Old 15th January 2004, 02:18 PM   #1
Default Woofer (not sub) to go with the W3-871S
Last week I built a pair of seales speakers with one Tangband W3-871S each. They sound marvelous! I really like them but they lack in the lower frequencies.
I could build a vented speaker with them ofcourse but I'm affraid it will exceed the xmax way too soon then.
Do you perhaps have a suggestion of a 5"/6.5" woofer to match them nicely?
I do live in the Netherlands, so Radioshack/Dayton isn't really a possibility for me. I will have to stick to the major brands here.. (Visaton, Vifa, Peerless etc)
Also (yeah I'm picky ) I would like not to exceed the 30liters (+/- 1.05 cubic feet) and spend way over 50 Euro's on each driver.
Thanks for your help
Old 15th January 2004, 02:27 PM   #2
Guss is offline Guss  Canada
Guss's Avatar
Peerless offers low priced drivers and they are leaders in bass application. I guess a pair of 6.5'' woof would be more than enough to match those TB you got there....
Old 15th January 2004, 09:01 PM   #3
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
I agree with Guss. Peerless is the leader when it comes to accurate and powerful bass in moderate-sized enclosures, and their Classic 5" and 6-1/2" woofers should be more than adequate at a good, low price.
Good luck. (And be sure to post your listening impressions with the woofers set up.)
KTK. Kool To the Kore.
Old 15th January 2004, 09:15 PM   #4
Seas aluminum.
Old 15th January 2004, 09:19 PM   #5
Guss's Avatar
Originally posted by cadmaniac
Seas aluminum.
A bit too expensive, lack of low end IMO.
Old 15th January 2004, 09:39 PM   #6
Wow.. thanks
I'll have a look at what Peerless has to offer to me
The Tangband can take it down to 115-120 or so.. so the woofers only have to play from maybe.. 130/150 and down? The midrange really isn't important here. (well offcourse it is, but its taken care of )
The units in my range are:
- CSC 145 G (54 euro)
- CSC 176 H (56 euro)
- CSX 145 H (56 euro)
Seas is above my budget..
Why is everything so expensive in the Netherlands?
Any comments on Visaton? The W130S and W170S are pretty affordable.
Thanks for all the feedback!
by the way.. would you recommend a 6,5" of a lower series or a 5" of a higher series?
Old 15th January 2004, 09:58 PM   #7
Guss's Avatar
Originally posted by Razorfist
by the way.. would you recommend a 6,5" of a lower series or a 5" of a higher series? [/B]
Definitively the 6.5inch
Old 18th January 2004, 08:51 PM   #8
coolkhoa's Avatar
Again, I'd agree with Guss and would recommend the 6.5" over the 5" just for its better bass performance. Heck, I'd recommend a Peerless 8" model, that is if you don't mind it being slightly "slower" than the 6.5" and occupy more space.
Best of luck to you.
Old 18th January 2004, 09:41 PM   #9
First of all, there might be a slight delay My receiver's left pre-amp is broken (digital connection works great, but with analog/radio the left speaker doesnt work) so it will have to go back to Marantz I'm affraid
Second, I found this woofer:
http://www.intertechnik.de/user/1010...s/1345058.html
It can be used in a 25 liter BR-housing and will have a -3dB of 35Hz!! And maybe I can get them for only 37 euro each
Too bad they're 4Ohm, so not very suitable for playing on a tube amp (don't have one.. but just in case )
Old 18th January 2004, 10:28 PM   #10
fireman is offline fireman  Canada
fireman's Avatar
Bonsoir Razorfist,
These TBs look really good. Would you mind sharing the construction details with a newbie ? I want to start with a small speaker in order to experiment a bit before I try something bigger.
I have been thinking about the Alegria Isa for a while but the sonotube thing on the insade of the cabinet worries me. I don't know why but I'd prefer something with 3 drivers instead of 4.
If someone in this forum with the knowledge required for this job would help me figure out how to do this in a regular "needle" box (ie without the sonotube inside) I would really appreciate it.
I guess I would need some kind of electronics to help with the baffle step. Help with this would also be very welcome.
W3-871S same that W3-871? matos81 Full Range 8 20th March 2006 04:35 PM
Tb W3-871s PeaveyBassist Multi-Way 4 14th January 2005 08:14 AM
TB w3-871s and low x-max markp Multi-Way 14 25th May 2004 11:26 PM
Minimus 7 woofer + TB w3-871S fireman Multi-Way 7 26th January 2004 05:57 PM
Page generated in 0.11728 seconds (81.13% PHP - 18.87% MySQL) with 11 queries
