Really fantastic. Do you plan to share filter details and drawings? This could be my next project.
The problem in open the project is the time that is small to document everything and give due support at all stages. I'll think about it, but now I have no way, unfortunately.
Tks,
Renato
Dears,
Testing with wonderful Audiopax (AudioPax)
Tks,
Renato
Tks,
Renato
I wasn't directly thinking about the size of the room, more about how reflective it appears to be.
A larger room does help by itself within reason but it will also give you more options to add methods absorption, diffusion and bass-trapping without it becoming too obtrusive.
Large, thick rugs on that tiled floor would be a good start and cloth-covered sofas usually make excellent bass traps. Quite a lot can be achieved if you keep acoustics in mind when decorating but I appreciate that being in Brazil has got to be another major consideration. (I just assume that it tends to be hot and humid which would make wall-to-wall carpeting for example a possibly bad idea.)
I'm not trying to be a d••k, I just think you take your system seriously enough to start thinking about room acoustics so you can release its maximum potential.
Charles
Thank you for your considerations
I have another room and that I'm doing a very special acoustic treatment. As this other room is relatively narrow and these very heavy boxes, I chose not to test the boxes that other room.
See:
Just as soon, I will be starting an acoustic treatment in the current room I showed the pictures,
Forte abraço,
Renato
See:
Forte abraço,
Renato
Dears,
I'm not fluent in English, although to read without any problem.
I'll try to post everything about this lovely little toy, one 3-way speaker and high sensibility.
First, picture on my modest system.
Hope you enjoy!
Tks,
Renato
Renato,
What's the sensitivity of these beautiful speakers? Do you think a 40W/ch, SET amp would have sufficient power to drive these beauties loudly enough in a 15.5 ft. W x 12.5 ft. D x 8 ft. to 10 ft. H sloped ceiling room?
TIA
I'm listening to: Afterdark by Halie Loren
Thetubeguy1954 (Tom Scata)
Grande Duda,
Bom te ver aqui!!!!
This mid is possibly the most spectacular I have ever had access, I'm amazed, a monster that can go up to 7 kHz...
With time, I will publish the graphs of measurements
Renato,
Should you need another pair of PHL drivers, please let me know.
I look forward to measured results (although I tend to favor my ears).
Cheers!
D
Dears,
Tks,
Renato
That is a nice setup - Eduardo would be happy with such "combo"...
Cheers!
D
Renato,
TIA
Has approximately 97dBs sensitivity
With 30W was very good in a greater than your space ... so I believe that should be enough ...
In his place I would consider a two-way with woofer and driver due to the simplicity and power loss due to the large inductors in a 3-way .
Also the proper impedance curve that can be important for a good reproduction with valve .
Tks,
Renato
I know...
- DAD Prime - My big loudspeaker toy :)
